I just received an STM32F303 Nucelo-64 board and am trying to run through the simple STM32CubeMX tutorial (https://visualgdb.com/tutorials/arm/stm32/cube/). I’m working on a Windows-10 PC (relatively new – so it has the latest O/S – but I’m not sure I have all the required drivers). Anyway, I followed the tutorial to the point of compiling the base code in Visual Studio and when I go to ‘Debug’ I get the error:
:56829: No connection could be made because the target machine actively refused it.
And when I look into the details of the connection, the following errors are listed:
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Error: open failed
in procedure ‘init’
in procedure ‘ocd_bouncer’
Online, it was suggested that I need to install the ‘WinUSB’ driver. However, Microsoft (https://msdn.microsoft.com/en-us/library/windows/hardware/ff540196(v=vs.85).aspx) indicates that WinUSB support is already in place (?). Is there some driver that I need to install?
Also, I am also running Bitdefender in the background. Not sure if that was a factor. I have since temporarily deactivated it and tried – but that did not seem to help.
This topic was modified 8 years, 7 months ago by
gboy.
