Hi
I’ve just started using VisualGDB, in VS Studio 2015. I have created the “Hello world” app described in the Linux tutorial.
If I make an intentional syntax error in my code and execute Build >Build solution I see:
1> Command exited with code 2
1> Executable: make
1> Arguments: CONFIG=Debug
1> Directory: /tmp/VisualGDB/c/Users/<snip>/Documents/VisualGDB_projects/LinuxProject1/LinuxProject1
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(37,5): error MSB3073: The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDB.exe” /build “C:\Users\daldrich\Documents\VisualGDB_projects\LinuxProject1\LinuxProject1\LinuxProject1.vcxproj” “/solution:C:\Users\<snip>\Documents\VisualGDB_projects\LinuxProject1\LinuxProject1.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
I had hoped to see a nice gcc error which I could click to go to the error in my source code. Is that possible?
Best regards
David
This topic was modified 9 years, 11 months ago by
DavidA.
