Sysprogs forums › Forums › VisualGDB › New error: Warn : unable to change server port after init
- This topic has 5 replies, 3 voices, and was last updated 9 years, 9 months ago by
sierra29.
June 14, 2016 at 14:41 #8416
karlis77
ParticipantI was using my STM32F0Discovery board as programmer as usual and suddenly when I tried to upload the new code it gave me this error: Warn : unable to change server port after init.(Full message text under the post)
I read that I can fix it by updating VisualGDB to the newest version, so I downloaded the msi file of install and installed it(it should have updated the vGDB I guess), but it did not solve it. At the moment I am using version 5.1 (build 712).
Can any1 please help me to fix this? Error text is down below.
C:\Users\KARlis\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -f interface/stlink-v2.cfg -f target/stm32f0x.cfg -c init -c “reset init” -c “gdb_port 50543” -c “telnet_port 50542” -c “gdb_port 59216” -c “telnet_port 59215” -c “echo VisualGDB_OpenOCD_Ready”
Open On-Chip Debugger 0.9.0 (2016-05-10) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport “hla_swd”. To override use ‘transport select ‘.
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 1000 kHz, using 950 kHz
Info : clock speed 950 kHz
Info : STLINK v2 JTAG v14 API v2 SWIM v0 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 2.916726
Info : stm32f0x.cpu: hardware has 4 breakpoints, 2 watchpoints
stm32f0x.cpu: target state: halted
xPSR: 0xc1000000 pc: 0x0800111c msp: 0x20008000
adapter speed: 8000 kHz
Error: jtag status contains invalid mode value – communication failure
Polling target stm32f0x.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Warn : unable to change server port after init-
This topic was modified 9 years, 10 months ago by
karlis77.
June 14, 2016 at 16:27 #8418support
It’s a known bug. Please update your VisualGDB to 5.1r6 and re-download the OpenOCD package via Tools->Embedded Tools Manager. This should resolve the problem.
June 14, 2016 at 20:50 #8419karlis77
ParticipantOk I will try that.
How to update the VisualGDB? Should I just download it from http://visualgdb.com/download/ ?
June 14, 2016 at 22:41 #8420support
Yes, this should do.
June 28, 2016 at 20:43 #8492sierra29
ParticipantHello,
I first had the same problem, but after doing above steps to solve the problem it did not dissapear but another error message appears now:
none separate
in procedure ‘init’
in procedure ‘ocd_bouncer’and a message box tells me “Open OCD exited with code 1. Please check your settings”
But before the last update all my projects run fine with exactly this settings and project files, now not one is working.
I use stm32F1xx devices with a ST-Link v2, what big shit happened there? Is there a solution to go back to my old configuration tho get my pending projects working again?
Thank you
June 28, 2016 at 20:51 #8493sierra29
ParticipantProblem solved:
After some friggling tests i recognized that the reinstallation has removed my winusb driver. I´ve installed winusb again and the problem was solved.
