Sysprogs forums › Forums › VisualGDB › my device not found
- This topic has 4 replies, 3 voices, and was last updated 11 years, 6 months ago by
martin.zima.
February 16, 2014 at 09:09 #726
ParticipantI’ve run command “adb devices” in cmd, and it shows one device, but I can’t find it in Visual Studio. I know that the device is correctly configured, as in Eclipse I can connect to it with no problem.
I’m using Windows 8.1, x64, 32bit Java and Visual Studio 2013 with extension vs-android 0.96February 16, 2014 at 18:02 #2901ket
VisualGDB uses the exact same “adb devices” command to locate devices. What is the exact error you are getting while debugging? Please try reconnecting the device.
February 17, 2014 at 08:16 #2902Anonymous
No android devices found.
D:Androidsdkplatform-toolsadb.exe devices
Command exited with code 0But when I start cmd and repeat it, I am getting:
List of devices attached
192.168.56.101:5555 deviceor when i turn off my emulator and connect my mobile phone
BX902Y69JR deviceI tried also reinstall VisualGDB, but no results.
February 18, 2014 at 06:36 #2903ket
This is strange, it looks almost looks like the same command gets a different reply. Hence a few troubleshooting questions below that can help clarify the issue.
1. When you run the command manually, are you running the exact same command “D:Androidsdkplatform-toolsadb.exe devices” i.e. definitely calling the same adb.exe?
2. Are you running Visual Studio and cmd.exe with different user rights i.e. one in admin mode the other not?
3. Is the complete adb log the following i.e. no “List of devices attached” line anywhere: ?D:Androidsdkplatform-toolsadb.exe devices Command exited with code 04. Are the connected devices sleeping (i.e. screen locked) when trying to debug with VisualGDB?
5. Which exact versions of Android SDK Tools, Android SDK Platform-tools, Android SDK Build-tools are you using? You can get the version numbers from the Android SDK Manager.
6. Which version of VisualGDB are you using?October 4, 2014 at 16:45 #2904martin.zima
ParticipantHi everyone,
have you solved this issue already? Today, I installed VisualGDB and I am having the exact same issues Krivers is describing. Even my configuration is pretty much the same (Windows 8.1 – Czech language version btw, x64, 32bit Java, Visual Studio 2013 and vs-android v0.961), so maybe there is a connection.
Ad your questions:
1) Yes, it is calling the same adb.exe.
2) Yes. I have also tried running VS with admin rights, but with no result.
3) No, all it shows me in the ‘ADB log’ tab is this:D:AndroidStudiosdkplatform-toolsadb.exe devices Command exited with code 0But it shows me this window only when I hit the debug button, i.e. not when I press ‘Android->Open Android shell’ for example.
4) Tried with both real device and emulator and they were not sleeping.
5) I am using SDK Revision 23.0.2 (it’s the latest version for now). I usually use the SDK bundled with the Android Studio, but I have tried with the standalone distribution as well.
6) I have installed VisualGDB 4.2r4 (trial).Can you help? Thanks.
