Sysprogs forums › Forums › VisualGDB › MSP430 Hardware Registers view not working
- This topic has 8 replies, 2 voices, and was last updated 4 years, 5 months ago by
PeterU.
October 11, 2021 at 01:32 #31492
PeterU
ParticipantUsing:
Microsoft Visual Studio Community 2019 Version 16.11.4
VisualGDB version 5.6(Beta 5, build 4336)
While debugging an MSP430FR2355 the Hardware Register window is blank no named registers. The variable watch widows does work as expected
Regards,
Daniel
October 11, 2021 at 09:30 #31501support
No problem, we can gladly look into this. Do you mind sharing a screenshot of the entire Visual Studio window demonstrating the issue? The screenshot should also show the Solution Explorer and at least one source file (it’s important for checking for common module loading issues).
October 11, 2021 at 10:58 #31506October 12, 2021 at 20:22 #31513support
KeymasterThanks, we have reproduced the issue and released an updated toolchain with the correct register definitions. You can install it via Tools->VisualGDB->Manage VisualGDB Packages.
October 12, 2021 at 21:15 #31515PeterU
ParticipantThanks, for updating the tool chain and fixing the errors; the hardware register view seems to operate properly.
On this new release the previous patch https://sysprogs.com/w/forums/topic/msp430-debug-probe-fails-to-reset-after-programming/ was not included, so I had to replace msp430-gdbproxy.exe again.
Note: I only replace msp430-gdbproxy.exe the MSP430.dll in the zip does not seem to work.
Regards,
Daniel
October 13, 2021 at 08:29 #31521support
KeymasterNo problem, we have updated the toolchain with the new msp430.dll. Feel free to re-download it via VisualGDB Package Manager (same revision number).
October 13, 2021 at 16:08 #31525PeterU
Thanks for your help downloaded the update, it now has the new .dll but uses has the old msp430-gdbproxy.exe. I had to copy the new msp430-gdbproxy.exe in to get “start without debugging”(Ctrl F5) to work.
I would have thought you would have the new msp430-gdbproxy.exe in the new package?
Thanks again
October 13, 2021 at 16:13 #31526support
KeymasterNo worries. The MSP430 toolchain has a relatively low priority, so we would normally only update the gdbproxy when releasing a new major update to minimize the risk of breaking backward compatibility.
That said, if you have been successfully using the new gdbproxy with the new msp430.dll for a while, the chance of unexpected issues is very low. We have updated the toolchain package again with the latest gdbproxy.
October 13, 2021 at 16:17 #31527PeterU
ParticipantThanks, current using it on a project and will inform you if I encounter any issues.
