MSB3073 error when building
Sysprogs forums › Forums › VisualGDB › MSB3073 error when building
  • #26792
    Hakim
    Am having a project and there i combine C code in C++ due to some libraries being written only in C. However, when i build, i end up with an error telling me that a certain command in the Make file caused the build to be unsuccessfull.
    I have attached the error-list window output to see what my errors list contains.
    Before, i removed all the C-related code files and it ended up working. But now its not building at all, even after removing all the C-related files. Has anyone come across this error? how did you get past it.
    I also tried running Visual studio with elevated privileges i.e as Administrator but all in vain.
    #26808
    As the error message suggests, please try checking the Output window for details. It will show a detailed build log including the lines that were not directly recognized as clickable error messages.
