Missing Hardware register definition on ESP32
Sysprogs forums › Forums › VisualGDB › Missing Hardware register definition on ESP32
  • #21369
    mattia
    I’m using VisualGDB 5.4 on an ESP32. When I try to debug, the window “Missing Hardware register definition” appears on my screen. Do I need to set anything?
    Thank you,
    Mattia
    #21372
    No problem, this looks like our bug. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.3.2349.msi
    #21378
    mattia
    Ok, now it works
    #21840
    mattia
    it seems that some registers are still missing (i.e. timer, uart, …). Here attached the register groups I can see. How can I see the other registers?
    Thank you,
    Mattia
    #21880
    No problem. The ESP32 register definitions are not 100% precise, as they are computed from parsing the ESP-IDF header files. We have updated the code responsible for parsing them to handle some of the previously missing registers (see the R11 toolchain release here).
    However, other registers (e.g. SPI, UART) that use non-trivial rules for computing the base addresses are still not included. As a workaround, please consider editing the <SysGCC>\esp32\esp-bsp\registers.xml file manually or hardcoding the rules for the missing register groups in our header file parser.
