Missing debug option for OpenOCD (run remotely)
Sysprogs forums › Forums › VisualGDB › Missing debug option for OpenOCD (run remotely)
  • #33351
    Bredlej
    Hello, I haven’t used VisualGDB for a while, and want to use it to debug a Raspberry Pico remotely through SWD via a Raspberry Pi 4B hardware.
    It worked a couple months before when I used it, but it seems the option is gone now. Here’s a tutorial from your site which I’m trying to follow for the SWD connection: Debugging Raspberry Pi Pico via SWD – VisualGDB Documentation.
    Attached is a screenshot with the available options in my debug settings.
    Did this option move somewhere in an update, or is there perhaps something wrong with my installation (I’m using VisualGDB Embedded Edition)?
    #33353
    As per the documentation page, running OpenOCD remotely is supported starting from the Linux edition. If you are using the lower Embedded edition, you can always upgrade it here: https://sysprogs.com/splm/mykey.
    If the feature worked earlier, it was likely during the trial period which is equivalent to the highest available Ultimate edition.
    #33357
    Bredlej
    Oh all right, got a bit confused there, thanks!
