Good to know.
I started an example with Arduino IDE (not a big fan), works after some efforts, mainly that this board creates 2 com ports, one for ESP32 and one for K210. However the K210 changes to a debug port, and I had to remove it, then I regained the correct com port, and was able to upload a file to the Maixdunio.
Once this worked, I tried to import the sketch to VisualGDB, but failed to setup the debugger, or com port.
FYI.
Regards
Johanan
You must be
