Loading QT on BBB using SmarTTY
Sysprogs forums Forums VisualGDB Loading QT on BBB using SmarTTY
  • #940
    heedaf
    I’m trying to SSH to my BBB using SmarTTY but I’ve been unsuccessful. I’ve got the BBB connected via a USB cable and Ethernet cable to my computer but the BBB isn’t found. Do I need to connect through a router in order to connect or what else could be the problem?
    #3472
    heedaf
    I connected the beaglebone to my router and when I use beaglebone for the host name I get “host name not found” When I type the address the DHCP gives .1.18 as the host name I get “LIBSSH2 returned LIBSSH_ERROR_SOCKET_RECV”. If I ping the board with 192.168.1.18 I get all the packets ok. Any idea????
    #3473
    Do you have the ssh server running on the beaglebone? Can you connect to itself via SSH (type “ssh localhost” via the USB console)?
    #3474
    heedaf
    Forgive me for asking a really dumb question but where do I find the “usb console”?
    #3475
    Sorry for being ambiguous. Please install the Beaglebone drivers. Once installed, they will create a virtual COM port (look in Device Manager for details) that should give you access to the Beaglebone console.
    #3476
    Colin.k
    I am also having this problem
    Just downloaded the trial version and started the Beagle bone tutorial
    got to the point of making the connection and stoped
    I am running win7 64bit ultimate
    BBB Debian Image 2014-05-14
    I can connect with putty via the usb and Ethernet
    If I use beaglebone as the host name I get no such host
    if is use the usb or Ethernet ip I get
    save key then
    LIBSSH2 returned LIBSSH2 error 0
    I reinstalled SSH server on the BBB
    any sugestions
    #3477
    The “error 0” usually indicates that the root password is empty. Please set it to a non-empty one and VisualGDB will be able to connect.
    #3478
    Colin.k
    That did the trick if I use the IP address but fails if I use the name beaglebone
    is this a problem with my PC settings or the BBB?
    #3479
    If your DHCP server is not configured to automatically send DNS updates for its clients (such as beaglebone), the easiest way would be to hardcode the IP address in %SystemRoot%SYSTEM32Driversetchosts.
