Linker file not included with custom project template
Sysprogs forums › Forums › VisualGDB › Linker file not included with custom project template
  • #8526
    CurtisHx
    I’m trying to create a custom project template.  I want to include the linker file with the project template, but it does not appear to be working.
    I started with a project to “templatize”, which has the linker script locally.  I went into VisualGDB Properties -> Makefile settings, and clicked on the “Make a local copy” button.  The linker script is in the project folder with the rest of the source files.
    I then made the project template by going to File-> Export VisualGDB Project Template and exporting the template.
    However, when I try to create a project from the template, the Linker script selection is empty under the “Device Selection” step, and linking the test project fails.  Once the project is created an I manually add the linker script by right clicking “Make files” and going to Add->Existing Item, everything is fine.  The linker script shows up under VisualGDB Properties->Makefile settings->Linker script.  It does not show up when creating the project from the template.
    The linker script does wind up in the project folder.
    How can I include the linker file when creating a project template?  I tried setting its “File Type” to Makefile in the project being templatized, but that did not have any effect.
    • This topic was modified 10 years, 2 months ago by CurtisHx.
    #8551
    Sorry for the delayed reply. Looks like there was a bug in our template exporting mechanism. We have fixed it in this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.5.936.msi
    If it still does not work, please let us know.
