Language translation topic (issues/questions)
Sysprogs forums › Forums › WinCDEmu › Language translation topic (issues/questions)
Viewing 1 post (of 1 total)
  • #407
    Zodarr
    Hello Bazis.
    I made this topic so if others have issues regarding translations, there would be one to write to.
    A problem I have, in my case, with hungarian language translation.
    • Case: There exists a previous hungarian translation, that I want to modify.
    • Problem: There is no comment/about or similar section in the LNG file.
    • Question: How can I credit the previous translator?
    Suggestions:
    • Create an “About” section in the LNG file
    • Create an “About” button in WinCDemu setting window
    Other stuff, but relevant to this:
      Mentioned in another topic, the problem with WinCDemu windows not being wide enough to contain translated strings (they are cut off).
      This is a problem in the case of hungarian language too.
      The thing You could do is:
    • Make the window(s) wider (fixed value), or
    • make them auto adjust to text string’s lenghts, or
    • a half-solution would be, that windows could be resizable, and WinCDemu would remember the size setting.
    Sorry if this was a bit long.
