Issues with the Raspberry Pi Camera-OpenCV tutorial
Sysprogs forums › Forums › VisualGDB › Issues with the Raspberry Pi Camera-OpenCV tutorial
  • #8126
    OSchofield
    I am having troubles with the OpenCV- Raspberry Pi Camera tutorial. I follow up to the first example code step, but when I try to debug the program
    I follow up to the first example code step, but when I try to debug the program, I receive the following GDB output:
    Process /tmp/libraspicam.so.0.1 created; pid = 1000
    Listening on port 2000
    Remote debugging from host 192.168.0.29
    Child terminated with signal = 0xb (SIGSEGV)
    GDBserver exiting
    Individually, the OpenCV tutorial works as well as the RaspiCam tutorial, but it seems putting the two together is not happening,
    Any suggestions?
    Thanks.
    #8127
    Yes, please try running it as root. If this does not help, double-check your camera connection, settings and try some other command-line tool for capturing images.
