For purposes of visualizing performance over time and for being able to document that performance over different configurations/versions, is there a way to read the value of a “time label” and perhaps set that value to a variable in code so to be able to send that value to a respective file using visualGDB’s TestResourceManager?
EDIT: I just figured out the problem to the question I had so instead I would like to ask to clarify if what I am doing is correct. In the picture attached I would like to give the variable DWT_CYCCNT the time it takes for AEInit() to execute. will setting breakpoints shown in the pick give me this? also, the variable reads 4614. Is this always going to be for units of nanoseconds?
And if I could slip one more question in, I cant find how to delete integration tests without going through xml?
This topic was modified 5 years ago by
AEHadi.
You must be
