Init mode failed (unable to connect to the target)
Sysprogs forums › Forums › VisualGDB › Init mode failed (unable to connect to the target)
  • #28125
    carneytom1981
    I’ve recently posted in another thread about a problem getting my STM32VLDiscovery board running
    (https://sysprogs.com/w/forums/topic/installing-st-link-drivers-on-discovery-board/)
    I have now reached a point where the device appears correctly in the device manager. However I am now getting a whole new error.  When I try to start remote debugging I get
    init mode failed (unable to connect to the target)
    When I click ‘view gdb stub log’ I get the attched log data
    In the GDB Session window of Visual Studio it says
    :49865: No connection could be made because the target machine actively refused it
    Any advice on how to proceed?
    #28127
    If this is the same board you mentioned before (where you had to hold the reset button in order to connect using the ST-Link utility), please make sure you do the same with VisualGDB. Please also try using the “connect under reset” checkbox.
    If nothing helps, please try checking if the board works when using the Eclipse-based STM32 IDE, that also uses OpenOCD.
