Sysprogs forums › Forums › VisualGDB › Indent case labes in VisualGDB
- This topic has 5 replies, 2 voices, and was last updated 4 years, 11 months ago by
kaworu.
March 23, 2021 at 03:50 #30216
kaworu
ParticipantHello.
Question, where in visualgdb I can find code formatting option option called “indent case labes” in visual studio? Or better it’s possible to give control over codeĀ formatting to visual studio engine completely?
You must be logged in to view attached files.March 23, 2021 at 07:45 #30218support
No problem, please see the following page for a detailed explanation of formatting-related settings: https://visualgdb.com/documentation/intellisense/
March 23, 2021 at 08:33 #30219kaworu
ParticipantExcept – It doesn’t work. Switched to “Regular Intellisense” (first screenshot), restarted VS, reloaded project, Ctrl+K,D and it still doesn’t follow VS’s formatting settings (see screenshots). Confirmed that on Clang Intellisense Diagnostic Console “Native VC++” is selected.
You must be logged in to view attached files.March 23, 2021 at 08:43 #30222support
KeymasterMost likely, you have selected an incompatible combination of settings at some point.
We can help you understand what is going on if you could share the steps for reproducing the problem from scratch per our problem reporting guidelines. Please make sure the steps include entire uncropped screenshots of all the relevant windows as shown in the “screenshots” section of the guidelines.
March 23, 2021 at 09:28 #30223kaworu
ParticipantFunny something new happened, I went to the options, Tools -> Options, Text Editor -> C/C++ (VisualGDB) -> Formatting Engine, changed “Default Formatting Engine” to “SysProgsFormat”, restarted VS, and now Ctrl+K,D works differently, but still not correctly – see attachment.
So for now my conclusion is, as follows:
- If Text Editor -> C/C++ -> Formatting -> Indentation, option “indent case labels” is selected
- And in Text Editor -> C/C++ (VisualGDB) -> Formatting Engine, “Default Formatting Engine” is set to “SysProgsFormat”, then indentation is made before case label – this is expected – and after case label – this is wrong;
- If in Text Editor -> C/C++ (VisualGDB) -> Formatting Engine, “Default Formatting Engine” is set to “Clang format”, then indentation is not made neither before nor after case label;
Also changing this options requires reloading the project, i would expect this change to be taken into account right away or at lest would be nice to have info somewhere, “changing this option requires restart”, or something.
You must be logged in to view attached files.March 23, 2021 at 09:54 #30225 -
