Incorrect syntax highlighting (VS Dark Theme)
Sysprogs forums Forums VisualGDB Incorrect syntax highlighting (VS Dark Theme)
  • #6650
    WoodyWoodsta
    Hey!
    Trying out VisualGDB V5 Beta 2 and everything is running smoothly. However, the syntax coloring is slightly off for Visual Studio’s dark theme. The only way I am able to correct this is if I change the VS theme to blue or light, and then back to dark.  Is this a known bug?
    Sean
    #6669
    Yes, this has been fixed in Beta 3.
    #6687
    WoodyWoodsta
    Great! Thank you!
    #6689
    WoodyWoodsta
    The Beta 3 update fixes the syntax highlighting issue in the dark Visual Studio theme, however, I am now getting dark backgrounds around text which overlays text selections as a result. This is rather unfortunate as it affects smart highlighting of similar variables/symbols. The link below shows the text background covering the selection colour.
    http://postimg.org/image/ult4mfkl9/
    #6711
    WoodyWoodsta
    I hate to do this – but I don’t think the above message was read!
    #6736
    Sorry for the late reply. We have looked into it and it looks like some internal VS bug, as we explicitly specify to use the default background color. We will be investigating this further and adding the workaround to it to VisualGDB 5.1.
