Frequent CLang Engine Crash
Sysprogs forums Forums VisualGDB Frequent CLang Engine Crash
  • #19870
    codex653
    Lately over the past several days I’ve been noticing a dramatic increase in the frequency with which the CLang intellisense engine is crashing. At this point it crashes every few minutes or so and is starting to interrupt my work flow. I’ve attached the associated minidump file it spat out. Any idea what’s up?
    #19871
    codex653
    Trying a different file extension…
    #19883
    Thanks for the dump file. It looks like it might be related to a recently solved problem. Could you please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.3.18.2019.msi
    If the problem persists, please attach an updated dump file so that we could investigate it.
    #19892
    codex653
    I’ve installed it and I’ll post back if anything goes awry. Thanks.
    #19905
    codex653
    Well, it worked fine enough for about a day or so, but it’s started back up again. I’ve attached the new dump file.
    #19909
    Thanks for the dump file. This actually looks like a known Clang bug that we have not been able to pinpoint yet. Clang crashes while trying to parse a comment after an #ifdef directive. If you could locate the place in the code responsible for this and send us a repro, we should be able to fix it.
    Another option (if you could get this to crash consistently) would be to try a debug build of the engine (https://sysprogs.com/files/tmp/CppEngineCore64.7z) and send us a full dump (if you get an ‘assertion failed’ message, please attach VS, click ‘retry’ and create a dump file). This should help us pinpoint and fix this.
    #19916
    codex653
    Interesting! If I manage to get some free time I’ll try and dig into it. Thanks for the update.
