Formatting engine crash/not responding
Sysprogs forums › Forums › VisualGDB › Formatting engine crash/not responding
  • #24584
    CrzyRndm
    VisualGDB: 5.4R4
    Project type: Embedded
    Formatting engine: clang-format, attached custom .clang-format file (NOTE: was not specified in visualGDB settings, found automatically in repository root)
    After some time (so far seems to be random, I’ve had it occur after <30 seconds or >10 minutes) formatting stops being applied to the file. The telltale sign is that creating a newline doesn’t indent at all. When this occurs, if I close the affected file and reopen formatting will be applied again.
    There is a lot of code being pulled in from previous projects at the moment so portions of code that won’t compile immediately is being pasted in frequently (although all compiler errors are normally resolved before the next fragment is pulled in)
    #24585
    CrzyRndm
    Upload again…
    #24600
    Thanks for reporting this. Based on your description, most likely something in your codebase causes the Clang formatting engine to enter an invalid state that would prevent it from properly computing the indentations. We have added a few extra checks that will automatically reset the formatting engine in case it is not able to produce any meaningful results. Please try this build: VisualGDB-5.4.104.3073.msi
    #24602
    CrzyRndm
    Testing now
    #24606
    codex653
    I have also been experiencing this issue quite frequently using the latest VGDB build at the moment (5.4R4 build 3031) and running on VS2019 Community Edition 16.0.0  Preview 5.0 as well as VS2017 Community Edition 15.9.11. I will install the linked VGDB build and test it too.
    #24609
    codex653
    After using it for around 30 min, this appears to be working much better.
    #24612
    CrzyRndm
    A full day with the linked build and I haven’t had a lockup. Thanks for the quick fix 🙂
    • This reply was modified 7 years, 5 months ago by CrzyRndm.
