Sysprogs forums › Forums › WinCDEmu › [fixed] Itunes and WINCDEMU incompatable
- This topic has 6 replies, 3 voices, and was last updated 15 years, 5 months ago by
Anonymous.
August 31, 2010 at 09:20 #225
michael.luttkus
ParticipantAfter a full night of testing on a brand new clean install of Win 7 64 bit, I can confirm, as you may know, that there is an incompatabliilty problem with iTunes and Wincdemu.
The problem seems to be, as stated everywhere on the forum, GearASPIWdm, but it may be more then just that.
I have a fresh install of windows 7, and the only 2 things installed are Wincdemu, and iTunes. Wincdemu was working before itunes, and does not work after the install of itunes. I stopped all apple services, and it still didn’t work. I even tried deleting the GearASPIWdm driver, and it still didn’t fix it.
After completely uninstalling all Apple software, wincdemu works like a charm.
Any ideas on how to get both iTunes and winCdemu to work at the same time?
August 31, 2010 at 09:49 #1546michael.luttkus
ParticipantAfter using devcon (devcon classfilter cdrom upper !GEARAspiWDM) it now works, but iTunes is still panicing when I start it.
September 2, 2010 at 03:32 #1547Anonymous
ParticipantYes, I tried installing this program on a reasonably fresh win7 install that has itunes and the geardvd registry filter, when I tried to install wincdemu the finding of drivers timed out and the program (wincdemu) was very hard to uninstall. I updated the geardvd drivers using this link http://www.gearsoftware.com/support/drivers.php but then my itunes started doing windows is configuring itunes every time it started, luckily after a few restarts this stopped.
October 20, 2010 at 11:34 #1548Anonymous
ParticipantThis is a real shame as WinCDemu looked like a program that I really wanted to use, but not at the expense of having to registry hack and cripple itunes.
October 21, 2010 at 23:16 #1549Anonymous
ParticipantiTunes is not “crippled” when the GEARaspiWDM filter is removed. iTunes will complain, but then start and run. The ONLY thing it will not do without its dll is burn a CD. Once you restore the filter, iTunes starts and runs without complaint. NOTE! You do not have to delete the dll … just remove/restore the filter in the registry. I use three batch files for this. One to test for the filter and start WinCDemu if okay. One to remove the filter before running WinCDemu. One to restore the filter after running WinCDemu. (Notice I renamed the program WinCDemulator to drop the Beta label – and “emu” is a bird anyway 🙂 )
___________________
1-startCDemulator.bat@echo off reg query HKLMSYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318} /v /f GEARAspiWDM /d>nul
if ERRORLEVEL 1 goto docmd
echo.
echo WARNING! Conflicting GEAR driver found in UpperFilters.
echo This will prevent CD emulator from running.
echo You must run "remove gear driver" before CD emulator.
echo.
pause
exit
:docmd
start /b winCDemulator.exe
_____________________
2-remove gear driver.bat@echo off reg query HKLMSYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318} /v /f GEARAspiWDM /d if ERRORLEVEL 0 goto remove echo GEAR driver not found - no change made goto endit :remove reg delete HKLMSYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318} /v UpperFilters if ERRORLEVEL 0 goto removed echo error removing GEAR driver goto endit :removed echo. echo GEAR driver removed echo. :endit pause__________________
3-add gear driver.bat@echo off reg query HKLMSYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318} /v /f GEARAspiWDM /d if ERRORLEVEL 1 goto add echo GEAR driver found - no change made goto endit :add reg add HKLMSYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318} /v UpperFilters /t REG_MULTI_SZ /d GEARAspiWDM if ERRORLEVEL 0 goto added echo error adding GEAR driver goto endit :added echo. echo GEAR driver added echo. :endit pauseOctober 27, 2010 at 11:02 #1550support
KeymasterFixed in version 3.4
May 17, 2011 at 04:56 #1551Anonymous
Participantconfirmed. this is fixed in 3.4 thank you very much!
