Failuer of OpenOCD
Sysprogs forums › Forums › VisualGDB › Failuer of OpenOCD
  • #20454
    donvukovic
    I have been trying to get OpenOCD working on VS_community and Visual GDB.
    After failing last Oct, I am trying again today.
    I have downloaded VS_Community, esp32-gcc5.2.0-r7.exe and  VisualGDB-5.3r8-trial and re-installed everything.
    I created the demo “HTTP Server”, it compiles with no errors.
    When I click Start Debugging (F5) it loads the file but actual debugging is not possible.
    I tried to bypass debugging and click “Program and Start without Debugging”
    This fails every time.
    I discovered that if I unplug the Olimex ARM-USB-OCD-H from my computer, the ESP32 HTTP Server will run.
    Making any changes to my source code, recompile I can not reload that file until I unplug the ESP32 board, the debugger and shut down VS_Community and restart everything, I may beable reload the newly compiled file.
    So, this is not a viable solution.
    I just wanted you to know.
    Don Vukovic
    303-818-3765
    #20457
    This looks like some sort of a wiring problem. Please double-check the power and reset connections and try using a different example (e.g. LEDBlink) to see the exact moment where the board starts/stops working.
