F4DISCOVERY FAIL TO CONNECT
Sysprogs forums › Forums › Analyzer2Go › F4DISCOVERY FAIL TO CONNECT
  • #29905
    E77TK
    i have problem with f4discovery at connection start.
    failure message was:
    Open On-Chip Debugger 0.10.0 (2020-05-03) [https://github.com/sysprogs/openocd]
    Licensed under GNU GPL v2
    For bug reports, read
    WARNING: interface/stlink-v2.cfg is deprecated, please switch to interface/stlink.cfg
    Info : clock speed 2000 kHz
    Info : STLINK v2 JTAG v14 API v2 SWIM v0 VID 0x0483 PID 0x3748
    Info : using stlink api v2
    Info : Target voltage: 2.911335
    Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
    Info : Listening on port 52598 for gdb connections
    xPSR: 0x01000000 pc: 0x0800422c msp: 0x20000c80
    SysprogsLogicAnalyzer_ReadyToConnect
    Connecting to port 52598…
    Successfully connected to OpenOCD.
    Unexpected device type. Expected 0x00000413, read 0x00000411. Please double-check that you have selected the board type correctly. If you have several boards connected, please ensure you select the correct one.
    Is there any solution for this connection problem??
    Thanks, Haris
    #29906
    It looks like your board revision is not supported. Please try using another board.
    #29907
    E77TK
    i have two but both are the same revision, is there any solution or forget about 🙁
    #29908
    Sorry, if a board revision is unsupported, Analyzer2Go will not work with it.
