Sysprogs forums › Forums › VisualGDB › Execute bash shell script
- This topic has 5 replies, 3 voices, and was last updated 9 years, 2 months ago by
January 16, 2017 at 14:05 #10081
hfrmobile
ParticipantExecuting bash shell script on the build host fails with a “directory invalid” error message. I recognized the reason: VisualGDB forgets the machine provided with “Run on remote computer”:
Visual GDB project settings: Custom Build Steps / After building
<span style=”text-decoration: underline;”>Action type:</span> Run a custom command line
<span style=”text-decoration: underline;”> Command:</span> ./test.shArguments:
<span style=”text-decoration: underline;”> Working directory:</span> ….
<span style=”text-decoration: underline;”> (*) Run on a remote computer:</span> Main buildĀ machine (hfr@192.168.x.y)Looks like a bug for me: When opening the “Edit Custom Action” dialog the “Run on a remote computer” field is blank. When I cancel the dialog, the action still works.
January 16, 2017 at 14:12 #10085hfrmobile
ParticipantBtw, the forum has also a bug: Sometimes it shows the HTML code instead of doing it (e.g. underline text – see above).
January 16, 2017 at 17:54 #10089ket
Thanks for reporting this. This usually happens when the ‘working directory’ field was left empty and not related to changing the remote machine. We agree this is confusing and will add better handling for this in the next release.
Regarding the forum, it’s a known bug of the forum engine we are using. As a workaround, please paste the text to Notepad, then copy it to clipboard again and paste it on the forum. This should clear all extra formatting and work around this.
January 17, 2017 at 10:11 #10093hfrmobile
ParticipantThank you for your response!
This is happening to me even when Working Directory is not empty and contains a valid value:
$(DeployDir)/VisualGDB/c/Development/xxx/trunk/Proj/xxx
I do verify the correctness of the directory by opening the “Folder Browser” which then points to the correct directory on the remote machine.
The bash script runs on the remove machine correctly. But when opening the “Edit Custom Action” dialog the “Remote Machine” field is empty (when hitting Cancel – everything works fine; when hitting OK then the remote machine setting will be overwritten by “blank value”.
How can I avoid that the “Remote Machine” will be emptied when opening the “Edit Custom Action” dialog?
January 17, 2017 at 10:14 #10096hfrmobile
ParticipantFYI: when changing the directory to /tmp/VisualGDB/c/Development/xxx/trunk/Proj/xxx it is automatically changed to $(DeployDir)/VisualGDB/c/Development/xxx/trunk/Proj/xxx
January 17, 2017 at 17:28 #10106support
This looks like a bug. Could you let us know where do you edit that custom action? Is it a part of the custom pre-build/pre-debug actions or something else?
