Sysprogs forums › Forums › VisualGDB › ESP32 IDF 4.1dev Missing Configs
- This topic has 8 replies, 2 voices, and was last updated 6 years, 11 months ago by
September 27, 2019 at 09:52 #25936
angel
ParticipantSeptember 27, 2019 at 15:13 #25940support
Sorry ESP-IDF 4.1 is not a stable release yet and hence is not supported by VisualGDB.
That said, ESP-IDF 4.0 had a similar issue and we fixed it in the following build: VisualGDB-5.5.1.3274.msi. Please feel free to try it as it may resolve the v4.1 issues as well.
October 1, 2019 at 13:11 #25974angel
Participantthank its worked
October 4, 2019 at 12:35 #26033angel
ParticipantI’ve realized now! I can view but cannot save properties
This reply was modified 6 years, 11 months ago by
angel.
October 4, 2019 at 15:53 #26035support
KeymasterThank you for your inquiry. Unfortunately, the description you provided does not sufficient details for us to reproduce the problem or pinpoint its location. Please describe the issue using the 3-step format shown here.
Please use accurate and precise descriptions for all the settings you change in the wizards and property pages, and also make sure describe the exact modifications you do to any configuration files.
Once we have a clear sequence of steps that allows reproducing the problem on our side, we are usually able to release a hotfix or advise a workaround promptly.
October 7, 2019 at 08:24 #26059angel
Participanti decided capture a video for better explaining.
there is no possible to change wifi coex in video.
October 7, 2019 at 17:00 #26062support
KeymasterUnfortunately, the video hosting you used doesn’t seem to work (video freezes after about 3 seconds of playback). Please try using a different hosting.
October 8, 2019 at 11:36 #26090angel
ParticipantOctober 8, 2019 at 18:31 #26106support
KeymasterSorry, we have tried reproducing this for the latest supported ESP-IDF version (4.0), but could not get the behavior shown in the video.
If you could confirm that the problem persists with ESP-IDF 4.0, please share the full repro steps from creating a project. If the problem is specific to ESP-IDF 4.1, please consider editing the configuration manually until ESP-IDF 4.1 reaches the “stable release” stage and is officially supported by VisualGDB.
