Sysprogs forums › Forums › VisualGDB › ESP32 5.2.0 R13 Toolchain Problems
- This topic has 2 replies, 2 voices, and was last updated 8 years ago by
October 3, 2018 at 12:12 #22188
nevyn
ParticipantI have a project that was building fine with the R12 toolset. I have just restarted VS and it has informed me that R13 is available. So I have just upgraded to R13 and now the project refuses to build.
I installed the R13 update (not side-by-side) and then restarted Visual Studio 2017.
I was greeted by an error message that stated that the R12 toolchain could not be found and so I opted to use the new R13 toolchain. I am now getting the following error:
Checking if any source files need uploading... C:\SysGCC\esp32\usr\bin\bash.exe --login -c "export IDF_PATH=/esp-idf/v3.1 && export BATCH_BUILD=1 && export PATH=/mingw32/bin:$PATH && export LANG=en_US && cd /cygdrive/c/GitHub/Meadow-ESP32/Source/MeadowComms && make partition_table BUILD_DIR_BASE='/cygdrive/c/GitHub/Meadow-ESP32/Source/MeadowComms/VisualGDBCache/MeadowComms-Debug-VisualGDB/CodeSenseDir' SDKCONFIG='/cygdrive/c/GitHub/Meadow-ESP32/Source/MeadowComms/VisualGDBCache/MeadowComms-Debug-VisualGDB/sdkconfig' V=0 && make -n -k BUILD_DIR_BASE='/cygdrive/c/GitHub/Meadow-ESP32/Source/MeadowComms/VisualGDBCache/MeadowComms-Debug-VisualGDB/CodeSenseDir' SDKCONFIG='/cygdrive/c/GitHub/Meadow-ESP32/Source/MeadowComms/VisualGDBCache/MeadowComms-Debug-VisualGDB/sdkconfig' V=0" Saved the code model to C:\GitHub\Meadow-ESP32\Source\MeadowComms\VisualGDBCache\MeadowComms-Debug-VisualGDB\BuildCommandLines.txt System.Exception: ESP-IDF build log did not report any built executables at z51.l.a_2(IEnumerable`1 a) at l2.j_2() at lk1.f()
I have tried cleaning the solution and reloading the project and also restarting Visual Studio 2017. Nothing seems to work.
I have also tried to create a new project using the R13 toolchain, the project type was ESP32 -> Peripherals -> UART Events and I am receiving the following error for this:Checking if any source files need uploading... Missing C:\GitHub\MeadowComms\sdkconfig-debug. Running C:\SysGCC\esp32\usr\bin\bash.exe --login -c "export IDF_PATH=/esp-idf/v3.1 && export BATCH_BUILD=1 && export PATH=/mingw32/bin:$PATH && export LANG=en_US && cd /cygdrive/c/GitHub/MeadowComms && make defconfig BUILD_DIR_BASE='/cygdrive/c/GitHub/MeadowComms/VisualGDBCache/MeadowComms-Debug-VisualGDB/CodeSenseDir' SDKCONFIG='/cygdrive/c/GitHub/MeadowComms/sdkconfig-debug' V=0"... l12: Command-line action failed at l91.m4(CommandLineAction d, String f, eb e, CommandFlags c, String b, Boolean a) at l91.b3(CustomActionBase e, eb c, Boolean b, String d, Boolean a) at z51.l.i_2(nc a) at l2.c(String a) at l2.j_2() at lk1.f()
Any thoughts on how I can resolve this?
Regards
MarkOctober 3, 2018 at 12:43 #22190nevyn
ParticipantSolved this by removing the ESP32 toolchain, installing latest preview and then installing the ESP32 toolchain once more.
Regards
MarkOctober 3, 2018 at 17:28 #22195support
Indeed the new toolchain in based on a different environment (MSYS2 vs Cygwin) and hence requires VisualGDB 5.4 Preview 6 or later in order to work correctly.
