ESP-IDF function link and syntactic colors
Sysprogs forums Forums VisualGDB ESP-IDF function link and syntactic colors
  • #24951
    julieninnovel
    I previously used Visual GDB with esp8266 NONOS SDK. Now I want to use the newest SDK with RTOS IDF style. So I’ve created a new project by selecting “ESP32/ESP8266 IDF/ASP Project Wizard”.
    All is working fine for build and flash the ESP8266.
    But, in the editor view, I can’t use the ctrl+click to go to the function definition and chnage the syntactic colors…
    I’m also using Visual Assist form Whole Tomoato to improove the syntactic colors, but nothing working…
    If I create a project with the “Embedded Project Wizard”, links and colors are OK, but I ‘m not using the IDF style…
    How can I get it working ?
    Thanks for your help.
    Best regards
    #24952
    Sorry, Visual Assist only works with regular VC++ projects (i.e. Embedded Project Wizard) and not with advanced projects such as the new ESP-IDF project type, as those projects are not based on VC++ and Visual Assist does not know how to attach to them.
    You can use the regular Tools->Options->Environment->Fonts and Colors to modify the syntax highlighting colors for both regular C/C++ and VisualGDB-based projects.
    If you are missing some fine-grain highlighting rules/settings, please feel free to let us know. The code highlighting for ESP-IDF projects is fully managed by VisualGDB, so we might be able to add a few extra cases there as long as it doesn’t require a major change on our side.
    #24955
    julieninnovel
    Ok thanks for your answer, I will ask it to Visual Assist support team.
    #24977
    julieninnovel
    I come back to you after discution with VA team.
    VA need a list of the code files that the solution contains.
    VA team ask me : “Do you know much about this project type, and the makefiles / CMakeLists.txt files that VisualGDB is generating?”
    Could you answer to this question ?
    I’ve open a ticket to VA Team, maybe you could discuss with them directly to try to solved the problem…
    Contact Colin at support@wholetomato.com and specify in the mail subject “(Case 140219) Visual Assist and Visual GDB”
    Both of VGDB and VA are important for me.
    Thank for your help.
    #24985
    No problem, we have contacted Whole Tomato with the case details and will update you once we get the tools integrated.
