Sysprogs forums › Forums › VisualGDB › ESP-ADF no import
- This topic has 26 replies, 2 voices, and was last updated 6 years, 2 months ago by
June 26, 2020 at 16:42 #28530
tcpipchip
ParticipantHi
I use the command line to compile the AMAZON esp-adf example
Why the VISUALGDB does not import it and compile ?
https://github.com/espressif/esp-va-sdk
June 26, 2020 at 17:25 #28532support
It is hard to say what is going on without knowing more details. Please share a screenshot of the Help->About VisualGDB window and the build errors you encounter and we can point you to the right direction.
June 26, 2020 at 20:33 #28539tcpipchip
ParticipantJune 26, 2020 at 20:35 #28544tcpipchip
ParticipantChecking if any source files need uploading…
Missing C:\msys32\home\tcpipchip\esp\esp-va-sdk\examples\amazon_alexa\sdkconfig-debug. Running c:\SysGCC\esp32\usr\bin\bash.exe –login -c “export ADF_PATH=/esp-adf/master && export BATCH_BUILD=1 && export PATH=/mingw32/bin:/usr/bin:$PATH && export -n PYTHONHOME && export LANG=en_US && cd /C/msys32/home/tcpipchip/esp/esp-va-sdk/examples/amazon_alexa && make defconfig BUILD_DIR_BASE=’/C/gbd/EmbeddedProject3/EmbeddedProject3/VisualGDBCache/EmbeddedProject3-Debug-VisualGDB/CodeSenseDir’ SDKCONFIG=’/C/msys32/home/tcpipchip/esp/esp-va-sdk/examples/amazon_alexa/sdkconfig-debug’ V=0″…
System.IO.FileNotFoundException: Could not find file ‘C:\msys32\home\tcpipchip\esp\esp-va-sdk\examples\amazon_alexa\sdkconfig-debug’.
File name: ‘C:\msys32\home\tcpipchip\esp\esp-va-sdk\examples\amazon_alexa\sdkconfig-debug’
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
at System.IO.File.Copy(String sourceFileName, String destFileName, Boolean overwrite)
at gg.a1.e_2(ue2 a)
at q1.k(String a)
at q1.q()
at wo1.i()and more images
You must be logged in to view attached files.June 26, 2020 at 20:54 #28547tcpipchip
Participantbe better you try to import! If possible!
https://github.com/espressif/esp-va-sdk (ESP-IDF 3.2)
I have success compile it on
msys32 (mingw32)
June 26, 2020 at 20:55 #28548support
KeymasterPlease share a screenshot of the Help->About VisualGDB window.
June 26, 2020 at 21:03 #28549June 26, 2020 at 21:10 #28553support
KeymasterThanks for the screenshots. Looks like you are using an older version of VisualGDB and an incompatible toolchain.
Please update to the latest VisualGDB 5.5 Preview 7 and follow our ESP-ADF tutorial to create a basic project. Make sure you use the v2.0 release of ESP-ADF, and not the master branch, and also a toolchain based on GCC 5.2.0 (ESP-ADF does not support the latest toolchain).
Once you are able to create a new ESP-ADF project from scratch, you should be able to import existing ones as well.
June 27, 2020 at 00:18 #28554tcpipchip
ParticipantI will test soon!!!!
We talk soon! Right ?
Good weekend!
This reply was modified 6 years, 3 months ago by
tcpipchip.
June 27, 2020 at 01:02 #28555support
KeymasterNo worries, we are happy to help you fix the issues with your project as a part of our consulting services. Feel free to reach out to our sales team to get a quote.
June 27, 2020 at 14:46 #28557tcpipchip
ParticipantJune 27, 2020 at 17:19 #28562support
KeymasterLooks like the project you are trying to import is not based on the original ESP-IDF or ESP-ADF, but requires the ESP-VA SDK that may not work with VisualGDB out-of-the-box. You might be able to get it working by addressing the VA SDK-specific issues on your side, however unfortunately we won’t be able to provide any help with this until we officially support this SDK.
We will continue monitoring the traction of the ESP-VA SDK and will consider adding out-of-the-box support for it once it becomes more popular.
June 27, 2020 at 19:22 #28563tcpipchip
Participantok! Thank you!
June 28, 2020 at 11:25 #28564tcpipchip
ParticipantBtw, i will write a blog soon how to use the VISUAL GDB and NINA W102.
Does the u$99,00 value allow ESP-IDF compile, right ?
June 28, 2020 at 13:39 #28565 -
