Error when creating a project from atollic
Sysprogs forums › Forums › VisualGDB › Error when creating a project from atollic
  • #21711
    moconnell
    I tried on a couple of different Atollic Projects…
    New->Project, VisualGDB, Embedded Project Wizard
    Import a project built with cmnd-line tools, Generate a Makefile-based project, Copy Imported files to project directory
    Select STM32F405VG, Flash, Hardware Floating Point
    Selected the folder with the Atollic project files and selected Import preserving directory structure.
    Creating project runs and then throws the following error…
    “Object reference not set to an instance of an object”
    VisualGDB version: 5.4.4.2394
    VS17.
    Any suggestions?
    -MO
    #21714
    Sorry, looks like you have omitted the stack trace (lines underneath the exception name) that contain information necessary to pinpoint the source of this. Please attach them as well and we should be able to see what is going on.
    If you are not sure, please post a screenshot of the error message as it is shown.
