Sysprogs forums › Forums › VisualGDB › error MSB3073
- This topic has 4 replies, 3 voices, and was last updated 9 years, 2 months ago by
August 31, 2016 at 07:38 #8940
akhilavit
ParticipantI want to run a sample project on Linux ()
It works fine when “main.cpp” is in “wrk” folder i.e. nearby Demo.sln
But when I move it in src folder, it gives me “error MSB3073”
-error description:
[VisualGDB : error : Command-line action failed
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.MakeFile.Targets(38,5): error MSB3073: The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDB.exe” /build “D:\User\Akhil\Ubuntu\Demo\Demo\wrk\RevLibDemo.vcxproj” “/solution:D:\User\Akhil\Ubuntu\Demo\Demo\wrk\RevLibDemo.sln” “/config:LinuxConfig” “/platform:Win32″” exited with code 1.]August 31, 2016 at 07:41 #8941akhilavit
ParticipantNote:
I want to port C++ code from windows to Linux
August 31, 2016 at 19:09 #8942support
It is hard to say what could be causing this without seeing the build log. Please open the Output window via the View menu and check for additional error information. If this does not help, please send us the build log so that we could help you further.
February 8, 2017 at 04:37 #10333Taisen
ParticipantI got the same error:
Error Build has failed. See the Output window for more details. Demo2 C:\Users\Taisen\Documents\STM32Cube_Generated\Demo2\Demo2\Demo2\EXEC 1
Error Command-line action failed Demo2 C:\Users\Taisen\Documents\STM32Cube_Generated\Demo2\Demo2\Demo2\VisualGDB 1
Warning ignoring old recipe for target `Debug/system_stm32f4xx.o’ Demo2 C:\Users\Taisen\Documents\STM32Cube_Generated\Demo2\Demo2\Demo2\Makefile 185
Error ld returned 1 exit status Demo2 C:\Users\Taisen\Documents\STM32Cube_Generated\Demo2\Demo2\Demo2\collect2.exe 1
Warning overriding recipe for target `Debug/system_stm32f4xx.o’ Demo2 C:\Users\Taisen\Documents\STM32Cube_Generated\Demo2\Demo2\Demo2\Makefile 473
Error MSB3073 The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\Users\Taisen\Documents\STM32Cube_Generated\Demo2\Demo2\Demo2\Demo2.vcxproj” “/solution:C:\Users\Taisen\Documents\STM32Cube_Generated\Demo2\Demo2\Demo2.sln” “/config:Debug” “/platform:Win32″” exited with code 1. Demo2 C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets 41I am following the video instruction here: https://www.youtube.com/watch?v=MFEzmGOmb-8
If I click the error, it will jump to Microsoft.MakeFile.targets
line 39-42:
<Target Name=”Build” DependsOnTargets=”PrepareForNMakeBuild;ResolveReferences;GetTargetPath;$(PreNMakeBuildTarget)” Returns=”$(NMakeManagedOutput)”>
<VCMessage Code=”MSB8005″ Type=”Warning” Arguments=”NMakeBuildCommandLine” Condition=”‘$(NMakeBuildCommandLine)’==””/>
<Exec Command=”$(NMakeBuildCommandLine)” Condition=”‘$(NMakeBuildCommandLine)’!=””/>
</Target>I do same as the video show, and there is no other errors… Please help!!!!!!!!!!
February 8, 2017 at 05:30 #10337support
Please select the View->Output command in Visual Studio just as the error suggests and you should be able to see more details about the error. Most likely you have 2 instances of the system file, so removing the reference to one of them via VisualGDB Project Properties -> Embedded Frameworks should resolve the problem.
