I’m trying to learn how to build CMake projects. The default Solution Explorer view seems to be the “MyProject.sln” view. Everything works fine in this view. Specifically, I get all the build commands in the Build drop down. However, I much prefer the “Folder View”. Unfortunately, in Folder View I don’t see any of the build commands in the Build drop down . I’ve tried this in a regular VS C++ console app project. As long as I clock on the “Run Code Analysis on Solution” Build menu item, I can build in both the folder view and the ConoleApplication1.sln view. I do get the “Run Code Analysis on Solution” Build menu item in my VisualGDB project (see attached screen shot) but it doesn’t seem to build the project.
This isn’t a show stopper but if there’s a way to work in folder view, that would be great.
This topic was modified 2 years, 8 months ago by
GeneM.
You must be
