Does not work with WDK 7600.16385.1
Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Does not work with WDK 7600.16385.1
  • #208
    #1454
    It looks like recent WDKs unified ntddk.h and is not anymore inside target specific directory. Visual DDK is expecting the wrong path for ntddk.h (wxp, w2k, etc
    ) for these wdk’s
    #1455
    Driver N00b
    I am having issues here also, not with paths, but with connecting to virtual machine kernel. see http://forum.sysprogs.org/viewtopic.php?f=4&t=523
    Did you manage to get everything going in the end?
    #1456
    I have the same problem. Is there any solution for it? There’ll be version for this WDK?
    #1457
    Just mkdir C:WinDDK7600.16385.1incddkwxp and copy ntddk.h into it. Then retry installation
    #1458
    Tried what you suggested – Installer still does not commence. Is visualddk any good at all if I get past the installation issues or is it incompatible with the current WDK anyway?
    #1459
    Dunno if this is an issue anymore, but I just declared WDKPATH to C:WinDDK7600.16385.1.
    Then I reconfigured VisualDDK and it all went OK. (I didn’t do any mkdir, just declared the environment variable above)
    (Running Windows 7, x64)
    #1460
    hey PLI, thanks for that info… worked like charm…
    #1461
    Fixing the WDK path fixed the issue.
