Developing Keil Projects With VisualGDB
Sysprogs forums › Forums › VisualGDB › Developing Keil Projects With VisualGDB
  • #20158
    blipton
    Regarding the tutorial,
    https://visualgdb.com/tutorials/arm/keil/
    I’m guessing (most?) people use Eclipse with gcc to compile/debug arm projects..    but I prefer using Keil’s uVision as setting up Eclipse has always been a struggle.
    But given a gnu-make project, is it even possible to compile that with the keil tools?   For example, can visualgdb import micropython (gcc/gnumake) and build with Keil?
    #20159
    GCC and Keil compilers are indeed not 100% compatible, so switching your project to a different compiler might require non-trivial adjustments. We only recommend using Keil with VisualGDB if you are trying to build existing Keil-specific code. For all other cases  we recommend using our GCC-based toolchain that is fully supported by all project types and works out-of-the-box.
