Sysprogs forums › Forums › VisualGDB › Debugging exited without any breakpoint hits from OpenCV tutorial
- This topic has 1 reply, 2 voices, and was last updated 9 years, 6 months ago by
March 26, 2017 at 02:54 #10807
cbarreiro
ParticipantFollowed: https://visualgdb.com/tutorials/raspberry/opencv/
Program wont run. Problem seems to be with:No symbol “disassembly” in current context.
Any help would be greatly appreciated!
GDBLog:
C:\SysGCC\Raspberry\bin\arm-linux-gnueabihf-gdb.exe –interpreter mi –args “C:\Users\Chris\Desktop\Pi-VS\OpenCvTest\OpenCvTest/Debug/OpenCvTest” /home/pi/lena.png
-gdb-version
=thread-group-added,id=”i1″
GNU gdb (GDB) 7.7.1
Copyright (C) 2014 Free Software Foundation, Inc.
This GDB was configured as “–host=i686-pc-mingw32 –target=arm-linux-gnueabihf”.
For help, type “help”.
Reading symbols from C:\Users\Chris\Desktop\Pi-VS\OpenCvTest\OpenCvTest/Debug/OpenCvTest…
done.
GNU gdb (GDB) 7.7.1
OK
-list-features
-gdb-set print demangle off
OK
-break-insert -f main
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x00013430″,func=”main(int, char**)”,file=”C:/Users/Chris/Desktop/Pi-VS/OpenCvTest/OpenCvTest/OpenCvTest.cpp”,fullname=”C:\\Users\\Chris\\Desktop\\Pi-VS\\OpenCvTest\\OpenCvTest\\OpenCvTest.cpp”,line=”30″,thread-groups=[“i1″],times=”0″,original-location=”main”}
-gdb-set solib-search-path C:/Users/Chris/Desktop/Pi-VS/OpenCvTest/OpenCvTest/Debug
OK
-gdb-show sysroot
-gdb-show debug-file-directory
^done,value=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot”
^done,value=”c:\\q\\gnu\\raspberrypi\\out\\lib\\debug”
-gdb-set debug-file-directory c:/sysgcc/raspberry/arm-linux-gnueabihf/sysroot/usr/lib/debug
-target-select remote 192.168.1.76:2000
OK
=thread-group-started,id=”i1″,pid=”8415″
=library-loaded,id=”/lib/ld-linux-armhf.so.3″,target-name=”/lib/ld-linux-armhf.so.3″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/ld-linux-armhf.so.3″,symbols-loaded=”0″,thread-group=”i1″
&”Cannot access memory at address 0x0\n”
*stopped,frame={addr=”0x76fcfd40″,func=”??”,args=[],from=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/ld-linux-armhf.so.3″},thread-id=”1″,stopped-threads=”all”,core=”0″
^connected
info shared
&”info shared\n”
From To Syms Read Shared Object Library
0x76fcf820 0x76fea4ec Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
OK
info target
&”info target\n”
Symbols from “C:\Users\Chris\Desktop\Pi-VS\OpenCvTest\OpenCvTest\Debug\OpenCvTest”.
Remote serial target in gdb-specific protocol:
Debugging a target over a serial line.
While running this, GDB does not access memory from…
Local exec file:
`C:\Users\Chris\Desktop\Pi-VS\OpenCvTest\OpenCvTest\Debug\OpenCvTest’, file type elf32-littlearm.
Entry point: 0x132a8
0x00010134 – 0x0001014d is .interp
0x00010150 – 0x00010170 is .note.ABI-tag
0x00010170 – 0x00010194 is .note.gnu.build-id
0x00010194 – 0x000106dc is .gnu.hash
0x000106dc – 0x000111ec is .dynsym
0x000111ec – 0x00012e1c is .dynstr
0x00012e1c – 0x00012f7e is .gnu.version
0x00012f80 – 0x00013000 is .gnu.version_r
0x00013000 – 0x00013018 is .rel.dyn
0x00013018 – 0x00013110 is .rel.plt
0x00013110 – 0x0001311c is .init
0x0001311c – 0x000132a4 is .plt
0x000132a8 – 0x00015214 is .text
0x00015214 – 0x0001521c is .fini
0x0001521c – 0x00015248 is .rodata
0x00015248 – 0x000154d4 is .ARM.extab
0x000154d4 – 0x0001562c is .ARM.exidx
0x0001562c – 0x00015630 is .eh_frame
0x00025630 – 0x00025638 is .init_array
0x00025638 – 0x0002563c is .fini_array
0x0002563c – 0x00025640 is .jcr
0x00025640 – 0x000257d0 is .dynamic
0x000257d0 – 0x0002585c is .got
0x0002585c – 0x0002586c is .data
0x00025870 – 0x00025990 is .bss
0x76fcf114 – 0x76fcf138 is .note.gnu.build-id in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf138 – 0x76fcf1f8 is .hash in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf1f8 – 0x76fcf2d4 is .gnu.hash in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf2d4 – 0x76fcf4a4 is .dynsym in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf4a4 – 0x76fcf647 is .dynstr in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf648 – 0x76fcf682 is .gnu.version in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf684 – 0x76fcf6e0 is .gnu.version_d in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf6e0 – 0x76fcf788 is .rel.dyn in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf788 – 0x76fcf7b8 is .rel.plt in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf7b8 – 0x76fcf814 is .plt in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fcf820 – 0x76fea4ec is .text in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fea4ec – 0x76fee0b0 is .rodata in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fee0b0 – 0x76fee104 is .ARM.extab in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fee104 – 0x76fee1a4 is .ARM.exidx in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76ffed40 – 0x76ffef44 is .data.rel.ro in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76ffef44 – 0x76ffeffc is .dynamic in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fff000 – 0x76fff050 is .got in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fff050 – 0x76fff884 is .data in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
0x76fff884 – 0x76fff958 is .bss in c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/ld-linux-armhf.so.3
OK
-exec-continue
^running
*running,thread-id=”all”
=library-loaded,id=”linux-vdso.so.1″,target-name=”linux-vdso.so.1″,host-name=”linux-vdso.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libarmmem.so”,target-name=”/usr/lib/arm-linux-gnueabihf/libarmmem.so”,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libarmmem.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_videostab.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_videostab.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_videostab.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_ts.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_ts.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_ts.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_superres.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_superres.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_superres.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_stitching.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_stitching.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_stitching.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_ocl.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_ocl.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_ocl.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_gpu.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_gpu.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_gpu.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_contrib.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_contrib.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_contrib.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_photo.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_photo.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_photo.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_legacy.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_legacy.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_legacy.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_video.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_video.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_video.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_objdetect.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_objdetect.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_objdetect.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_ml.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_ml.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_ml.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_calib3d.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_calib3d.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_calib3d.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_features2d.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_features2d.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_features2d.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_highgui.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_highgui.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_highgui.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_imgproc.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_imgproc.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_imgproc.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_flann.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_flann.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_flann.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopencv_core.so.2.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libopencv_core.so.2.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_core.so.2.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libstdc++.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libstdc++.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libstdc++.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libm.so.6″,target-name=”/lib/arm-linux-gnueabihf/libm.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libm.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libgcc_s.so.1″,target-name=”/lib/arm-linux-gnueabihf/libgcc_s.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libgcc_s.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libc.so.6″,target-name=”/lib/arm-linux-gnueabihf/libc.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libc.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libdl.so.2″,target-name=”/lib/arm-linux-gnueabihf/libdl.so.2″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libdl.so.2″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libpthread.so.0″,target-name=”/lib/arm-linux-gnueabihf/libpthread.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libpthread.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/librt.so.1″,target-name=”/lib/arm-linux-gnueabihf/librt.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/librt.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libGLU.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libGLU.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libGLU.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libGL.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libGL.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libGL.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libSM.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libSM.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libSM.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libICE.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libICE.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libICE.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libX11.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libX11.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libX11.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXext.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libXext.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXext.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libz.so.1″,target-name=”/lib/arm-linux-gnueabihf/libz.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libz.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libjpeg.so.62″,target-name=”/usr/lib/arm-linux-gnueabihf/libjpeg.so.62″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libjpeg.so.62″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libpng12.so.0″,target-name=”/lib/arm-linux-gnueabihf/libpng12.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libpng12.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libtiff.so.5″,target-name=”/usr/lib/arm-linux-gnueabihf/libtiff.so.5″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libtiff.so.5″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libjasper.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libjasper.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libjasper.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libImath.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libImath.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libImath.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libIlmImf.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libIlmImf.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libIlmImf.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libIex.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libIex.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libIex.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libHalf.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libHalf.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libHalf.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libIlmThread.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libIlmThread.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libIlmThread.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgtk-x11-2.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libgtk-x11-2.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgtk-x11-2.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgdk-x11-2.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libgdk-x11-2.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgdk-x11-2.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libpangocairo-1.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libpangocairo-1.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libpangocairo-1.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libatk-1.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libatk-1.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libatk-1.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libcairo.so.2″,target-name=”/usr/lib/arm-linux-gnueabihf/libcairo.so.2″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libcairo.so.2″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgdk_pixbuf-2.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libgdk_pixbuf-2.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgdk_pixbuf-2.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgio-2.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libgio-2.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgio-2.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libpangoft2-1.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libpangoft2-1.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libpangoft2-1.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libpango-1.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libpango-1.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libpango-1.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgobject-2.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libgobject-2.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgobject-2.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libglib-2.0.so.0″,target-name=”/lib/arm-linux-gnueabihf/libglib-2.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libglib-2.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libfontconfig.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libfontconfig.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libfontconfig.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libfreetype.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libfreetype.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libfreetype.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgthread-2.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libgthread-2.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgthread-2.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/libgtkglext-x11-1.0.so.0″,target-name=”/usr/lib/libgtkglext-x11-1.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/libgtkglext-x11-1.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/libgdkglext-x11-1.0.so.0″,target-name=”/usr/lib/libgdkglext-x11-1.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/libgdkglext-x11-1.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXmu.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libXmu.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXmu.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXt.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libXt.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXt.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libpangox-1.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libpangox-1.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libpangox-1.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgmodule-2.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libgmodule-2.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgmodule-2.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libdc1394.so.22″,target-name=”/usr/lib/arm-linux-gnueabihf/libdc1394.so.22″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libdc1394.so.22″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libv4l1.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libv4l1.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libv4l1.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libavcodec.so.56″,target-name=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libavcodec.so.56″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libavcodec.so.56″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libavformat.so.56″,target-name=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libavformat.so.56″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libavformat.so.56″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libavutil.so.54″,target-name=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libavutil.so.54″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libavutil.so.54″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libswscale.so.3″,target-name=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libswscale.so.3″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libswscale.so.3″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libexpat.so.1″,target-name=”/lib/arm-linux-gnueabihf/libexpat.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libexpat.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxcb-dri3.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libxcb-dri3.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-dri3.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxcb-present.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libxcb-present.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-present.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxcb-sync.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libxcb-sync.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-sync.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxshmfence.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libxshmfence.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxshmfence.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libglapi.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libglapi.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libglapi.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXdamage.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libXdamage.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXdamage.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXfixes.so.3″,target-name=”/usr/lib/arm-linux-gnueabihf/libXfixes.so.3″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXfixes.so.3″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxcb-glx.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libxcb-glx.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-glx.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxcb-dri2.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libxcb-dri2.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-dri2.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxcb.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libxcb.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxcb.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXxf86vm.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libXxf86vm.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXxf86vm.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libdrm.so.2″,target-name=”/usr/lib/arm-linux-gnueabihf/libdrm.so.2″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libdrm.so.2″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libuuid.so.1″,target-name=”/lib/arm-linux-gnueabihf/libuuid.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libuuid.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/liblzma.so.5″,target-name=”/lib/arm-linux-gnueabihf/liblzma.so.5″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/liblzma.so.5″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libjbig.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libjbig.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libjbig.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXcomposite.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libXcomposite.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXcomposite.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXrender.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libXrender.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXrender.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXinerama.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libXinerama.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXinerama.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXi.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libXi.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXi.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXrandr.so.2″,target-name=”/usr/lib/arm-linux-gnueabihf/libXrandr.so.2″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXrandr.so.2″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXcursor.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libXcursor.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXcursor.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libpixman-1.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libpixman-1.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libpixman-1.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxcb-render.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libxcb-render.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-render.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libselinux.so.1″,target-name=”/lib/arm-linux-gnueabihf/libselinux.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libselinux.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libresolv.so.2″,target-name=”/lib/arm-linux-gnueabihf/libresolv.so.2″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libresolv.so.2″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libthai.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libthai.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libthai.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libffi.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libffi.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libffi.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libpcre.so.3″,target-name=”/lib/arm-linux-gnueabihf/libpcre.so.3″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libpcre.so.3″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libraw1394.so.11″,target-name=”/usr/lib/arm-linux-gnueabihf/libraw1394.so.11″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libraw1394.so.11″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libusb-1.0.so.0″,target-name=”/lib/arm-linux-gnueabihf/libusb-1.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libusb-1.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libv4l2.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libv4l2.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libv4l2.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libavresample.so.2″,target-name=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libavresample.so.2″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libavresample.so.2″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libxvidcore.so.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libxvidcore.so.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libxvidcore.so.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libx264.so.142″,target-name=”/usr/lib/arm-linux-gnueabihf/neon/vfp/libx264.so.142″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libx264.so.142″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/vfp/neon/libvpx.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/vfp/neon/libvpx.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/vfp/neon/libvpx.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libvorbisenc.so.2″,target-name=”/usr/lib/arm-linux-gnueabihf/libvorbisenc.so.2″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libvorbisenc.so.2″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libvorbis.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libvorbis.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libvorbis.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libtheoraenc.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libtheoraenc.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libtheoraenc.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libtheoradec.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libtheoradec.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libtheoradec.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libspeex.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libspeex.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libspeex.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libschroedinger-1.0.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libschroedinger-1.0.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libschroedinger-1.0.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopus.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libopus.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopus.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libopenjpeg.so.5″,target-name=”/usr/lib/arm-linux-gnueabihf/libopenjpeg.so.5″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libopenjpeg.so.5″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libmp3lame.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libmp3lame.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libmp3lame.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgsm.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libgsm.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgsm.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libva.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libva.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libva.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/librtmp.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/librtmp.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/librtmp.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgnutls-deb0.so.28″,target-name=”/usr/lib/arm-linux-gnueabihf/libgnutls-deb0.so.28″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgnutls-deb0.so.28″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libbz2.so.1.0″,target-name=”/lib/arm-linux-gnueabihf/libbz2.so.1.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libbz2.so.1.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXau.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libXau.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXau.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libXdmcp.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libXdmcp.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libXdmcp.so.6″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgraphite2.so.3″,target-name=”/usr/lib/arm-linux-gnueabihf/libgraphite2.so.3″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgraphite2.so.3″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libdatrie.so.1″,target-name=”/usr/lib/arm-linux-gnueabihf/libdatrie.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libdatrie.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/lib/arm-linux-gnueabihf/libudev.so.1″,target-name=”/lib/arm-linux-gnueabihf/libudev.so.1″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/lib/arm-linux-gnueabihf/libudev.so.1″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libv4lconvert.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libv4lconvert.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libv4lconvert.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libogg.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libogg.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libogg.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/liborc-0.4.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/liborc-0.4.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/liborc-0.4.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libhogweed.so.2″,target-name=”/usr/lib/arm-linux-gnueabihf/libhogweed.so.2″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libhogweed.so.2″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libnettle.so.4″,target-name=”/usr/lib/arm-linux-gnueabihf/libnettle.so.4″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libnettle.so.4″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libgmp.so.10″,target-name=”/usr/lib/arm-linux-gnueabihf/libgmp.so.10″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libgmp.so.10″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libp11-kit.so.0″,target-name=”/usr/lib/arm-linux-gnueabihf/libp11-kit.so.0″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libp11-kit.so.0″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/usr/lib/arm-linux-gnueabihf/libtasn1.so.6″,target-name=”/usr/lib/arm-linux-gnueabihf/libtasn1.so.6″,host-name=”c:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot/usr/lib/arm-linux-gnueabihf/libtasn1.so.6″,symbols-loaded=”0″,thread-group=”i1″
=breakpoint-modified,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x00013430″,func=”main(int, char**)”,file=”C:/Users/Chris/Desktop/Pi-VS/OpenCvTest/OpenCvTest/OpenCvTest.cpp”,fullname=”C:\\\\Users\\\\Chris\\\\Desktop\\\\Pi-VS\\\\OpenCvTest\\\\OpenCvTest\\\\OpenCvTest.cpp”,line=”30″,thread-groups=[“i1″],times=”1″,original-location=”main”}
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”1″,frame={addr=”0x00013430″,func=”main”,args=[{name=”argv”,value=”0x7efff954″}],file=”C:/Users/Chris/Desktop/Pi-VS/OpenCvTest/OpenCvTest/OpenCvTest.cpp”,fullname=”C:\\Users\\Chris\\Desktop\\Pi-VS\\OpenCvTest\\OpenCvTest\\OpenCvTest.cpp”,line=”30″},thread-id=”1″,stopped-threads=”all”,core=”0″
info shared
&”info shared\n”
No linux-vdso.so.1
0x76fba568 0x76fbe2c4 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libarmmem.so
0x76f6ab58 0x76f902bc Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_videostab.so.2.4
0x76ec6ad8 0x76f407d0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_ts.so.2.4
0x76e6da78 0x76e95138 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_superres.so.2.4
0x76dfb158 0x76e4f054 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_stitching.so.2.4
0x76c41a78 0x76d287c0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_ocl.so.2.4
0x76bd19e0 0x76c12fcc Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_gpu.so.2.4
0x76b13bf0 0x76ba4120 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_contrib.so.2.4
0x76aced70 0x76ae36c8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_photo.so.2.4
0x769ef4b0 0x76aaa5a0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_legacy.so.2.4
0x7697b120 0x769b8230 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_video.so.2.4
0x76909d30 0x769561ec Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_objdetect.so.2.4
0x7688bcd0 0x768e193c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_ml.so.2.4
0x767f9e70 0x76862668 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_calib3d.so.2.4
0x76761450 0x767d2150 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_features2d.so.2.4
0x7670e248 0x76736970 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_highgui.so.2.4
0x764e0d98 0x7663f664 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_imgproc.so.2.4
0x7645c488 0x76495940 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_flann.so.2.4
0x76257108 0x763f1714 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopencv_core.so.2.4
0x76194b78 0x76201a70 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libstdc++.so.6
0x760d6c70 0x76107520 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libm.so.6
0x760b3160 0x760c201c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libgcc_s.so.1
0x75f7ac40 0x7606fad8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libc.so.6
0x75f52990 0x75f5376c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libdl.so.2
0x75f2e070 0x75f3c0bc Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libpthread.so.0
0x75f14830 0x75f18220 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/librt.so.1
0x75eb7e88 0x75f01cf0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libGLU.so.1
0x75e29f90 0x75e928a0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libGL.so.1
0x75e0a484 0x75e0e7e0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libSM.so.6
0x75dee46c 0x75dfb7b8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libICE.so.6
0x75ce8a38 0x75d68afc Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libX11.so.6
0x75cb8880 0x75cc3568 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXext.so.6
0x75c9086c 0x75ca0a54 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libz.so.1
0x75c3c9b0 0x75c6b31c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libjpeg.so.62
0x75c0d680 0x75c2541c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libpng12.so.0
0x75b97500 0x75bd4994 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libtiff.so.5
0x75b3d5b8 0x75b72930 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libjasper.so.1
0x75b227f0 0x75b240e0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libImath.so.6
0x75a90928 0x75ac61ec Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libIlmImf.so.6
0x75a58f9c 0x75a5f3e4 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libIex.so.6
0x759fa8c4 0x759fae40 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libHalf.so.6
0x759e7160 0x759e8720 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libIlmThread.so.6
0x756720c8 0x758fac58 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgtk-x11-2.0.so.0
0x755923d0 0x755ed024 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgdk-x11-2.0.so.0
0x755674b8 0x7556c0ac Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libpangocairo-1.0.so.0
0x7553e698 0x7554cbc0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libatk-1.0.so.0
0x75451f58 0x755110b4 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libcairo.so.2
0x7541a820 0x75430cd4 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgdk_pixbuf-2.0.so.0
0x752eebb0 0x753d3534 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgio-2.0.so.0
0x752ac3a0 0x752b4cf8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libpangoft2-1.0.so.0
0x7526e998 0x75291240 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libpango-1.0.so.0
0x75213720 0x75249cb0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgobject-2.0.so.0
0x7511d428 0x7519efb0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libglib-2.0.so.0
0x750c97c0 0x750e7f70 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libfontconfig.so.1
0x75035b64 0x7509e494 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libfreetype.so.6
0x7501b528 0x7501b730 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgthread-2.0.so.0
0x75010f44 0x75011c80 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/libgtkglext-x11-1.0.so.0
0x74fdf208 0x75002534 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/libgdkglext-x11-1.0.so.0
0x74fab368 0x74fb8ce4 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXmu.so.6
0x74f5d64c 0x74f958c8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXt.so.6
0x74f288d8 0x74f2ef6c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libpangox-1.0.so.0
0x74f11d20 0x74f12e38 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgmodule-2.0.so.0
0x74e94fb8 0x74eb8d74 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libdc1394.so.22
0x74e78b90 0x74e7be48 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libv4l1.so.0
0x74233080 0x746bd544 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libavcodec.so.56
0x741041b0 0x741dfb14 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libavformat.so.56
0x740c7bd8 0x740dd39c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libavutil.so.54
0x7408a2e0 0x740b0764 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libswscale.so.3
0x74058178 0x74073914 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libexpat.so.1
0x7404b990 0x7404bfa8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-dri3.so.0
0x7404097c 0x740410d4 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-present.so.0
0x740347e4 0x74036150 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-sync.so.1
0x74020738 0x74020ac8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxshmfence.so.1
0x73fee040 0x73ffe210 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libglapi.so.0
0x73fcc89c 0x73fcd314 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXdamage.so.1
0x73fbff90 0x73fc2298 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXfixes.so.3
0x73fb5478 0x73fb5604 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1
0x73fa413c 0x73fa9af0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-glx.so.0
0x73f91324 0x73f920b8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-dri2.so.0
0x73f790ac 0x73f852dc Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxcb.so.1
0x73f64c98 0x73f67468 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXxf86vm.so.1
0x73f49b84 0x73f51aa0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libdrm.so.2
0x73f32f04 0x73f34a64 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libuuid.so.1
0x73f0cf48 0x73f22930 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/liblzma.so.5
0x73eeee3c 0x73ef6cf0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libjbig.so.0
0x73ee39fc 0x73ee447c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXcomposite.so.1
0x73ed2638 0x73ed8054 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXrender.so.1
0x73ec68c8 0x73ec71cc Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXinerama.so.1
0x73eb29b8 0x73ebc59c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXi.so.6
0x73ea24a0 0x73ea7a50 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXrandr.so.2
0x73e92248 0x73e96da0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXcursor.so.1
0x73de7250 0x73e77e3c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libpixman-1.so.0
0x73dd79d4 0x73dd82b4 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0
0x73dcaa44 0x73dcd5fc Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxcb-render.so.0
0x73d9f7f4 0x73db29bc Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libselinux.so.1
0x73d78540 0x73d85b1c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libresolv.so.2
0x73d1e2a8 0x73d54418 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0
0x73d0a5a4 0x73d0dd0c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libthai.so.0
0x73cfa354 0x73cfec34 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libffi.so.6
0x73c87034 0x73cd4af0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libpcre.so.3
0x73c74484 0x73c7ae9c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libraw1394.so.11
0x73c57ce4 0x73c641fc Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libusb-1.0.so.0
0x73c39320 0x73c3ee78 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libv4l2.so.0
0x73c1a530 0x73c2499c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libavresample.so.2
0x73b1b528 0x73b96974 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libxvidcore.so.4
0x739b2800 0x73a7112c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/neon/vfp/libx264.so.142
0x73826a30 0x7393e22c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/vfp/neon/libvpx.so.1
0x73798d40 0x7379b3b8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libvorbisenc.so.2
0x7375c710 0x73771fe8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libvorbis.so.0
0x73713e50 0x737393f8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libtheoraenc.so.1
0x736effd0 0x7370094c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libtheoradec.so.1
0x736ca790 0x736da99c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libspeex.so.1
0x7362ac00 0x73683aac Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libschroedinger-1.0.so.0
0x735d0910 0x736054b8 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopus.so.0
0x735a3288 0x735bb798 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libopenjpeg.so.5
0x7352c5c0 0x73556a5c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libmp3lame.so.0
0x73514f10 0x7351d400 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgsm.so.1
0x734f1874 0x734fd364 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libva.so.1
0x734ca798 0x734d9c94 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/librtmp.so.1
0x733d1d1c 0x7349f618 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgnutls-deb0.so.28
0x733a2020 0x733aea4c Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libbz2.so.1.0
0x73396b7c 0x73397790 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXau.so.6
0x7338af6c 0x7338c554 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libXdmcp.so.6
0x7335d838 0x73375c10 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgraphite2.so.3
0x73350d88 0x73353be0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libdatrie.so.1
0x733356c4 0x7333d564 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/lib/arm-linux-gnueabihf/libudev.so.1
0x732afd20 0x732c89c4 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libv4lconvert.so.0
0x732a1428 0x732a4378 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libogg.so.0
0x7322695c 0x7327e2c0 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/liborc-0.4.so.0
0x731eabfc 0x731f5418 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libhogweed.so.2
0x731aa504 0x731caaa4 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libnettle.so.4
0x7313cb00 0x7318b634 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libgmp.so.10
0x730f8bd4 0x73116464 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libp11-kit.so.0
0x730d3818 0x730de778 Yes c:\sysgcc\raspberry\arm-linux-gnueabihf\sysroot/usr/lib/arm-linux-gnueabihf/libtasn1.so.6
OK
-break-delete 1
OK
-exec-continue
^running
=thread-group-exited,id=”i1″,exit-code=”01″
*stopped,reason=”exited”,exit-code=”01″March 28, 2017 at 04:24 #10812support
According to your log, the program exits normally with code 1. This usually indicates an error, so please check the Program Output window for the error messages shown by the program.
