Good afternoon,
I am trying to build an application for BeagleBoneBlack using VisualGDB, and the only problem I have is that I need to use the onboard Ethernet (usb0) to communicate with a linux machine, but I’m doing code development on a windows machine. Instead of transferring the files and having to re-connect usb0 (which is an ethernet adapter) I would like to be able to program the beaglebone via the 6 pin serial header. Is this possible with VisualGDB?
I could use the other ethernet adapter (eth0), but its very buggy and sometimes shuts down. Also when I open sockets and exit the software incorrectly, it forces me to restart the device to re-connect to it, with a serial connection I would not have to do this.
So, if it’s possible, how can I connect and debug my beaglebone with VisualGDB through a serial connection?
-D
