DEbug issue: no executable file
Sysprogs forums › Forums › VisualGDB › DEbug issue: no executable file
  • #10287
    amigo421
    what does it mean – no executable file specified. use exec or exec-file command?
    I see the executable built successfully. upload is not required as I’m in WSL, and refers to the same folder from Win10 as well as from WSL.
    the project was created as an import of CMake based project.
    #10289
    amigo421
    seems visualgdb interprets cmake oddly (incorrect?).
    cmake_minimum_required (VERSION 3.5)
    project(my_project)
    add_executable(my_project main.cpp src/handler.cpp)
    target_link_libraries(my_project pthread boost_system crypto ssl cpprest swe “${LIBRARIES_FROM_REFERENCES}”)
    the case above works fine.
    however (more correct for cmake , from my perspective) doesn’t work with error from the initial post
    project(my_project)
    add_executable(${PROJECT_NAME} main.cpp src/handler.cpp)
    target_link_libraries(${PROJECT_NAME} pthread boost_system crypto ssl cpprest swe “${LIBRARIES_FROM_REFERENCES}”)
    #10296
    Thanks for reporting this, please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.14.1375.msi
