CubeMX and DSP Library
Sysprogs forums › Forums › VisualGDB › CubeMX and DSP Library
  • #24591
    filiporlo
    Hi!
    I use VisualGDB with CubeMX everything is working great. But I don’t know how to include DSP Library from ARM. Canon anyone help?
    #24594
    The easiest way to do that would be to simply add the file (or the related sources) to the project via Add->Existing Items. If you are adding source files, please ensure that the directories with the header files are listed in the VisualGDB Project Properties -> Build Settings -> Include Directories.
