Sysprogs forums › Forums › VisualGDB › Cortex core registers
- This topic has 15 replies, 4 voices, and was last updated 8 years ago by
December 21, 2016 at 15:57 #9842
tw39124
ParticipantI am debugging a project on an STM32F439, which is a Cortex-M4 based MCU. I can use the Hardware Registers window to see all of the STM peripheral registers (GPIO, UART etc) without any problem.
However, there does not seem to be a nice user interface by which I can view the core Cortex-M registers. I’m not talking about the generic CPU registers that I can view in the Visual Studio registers window (r0, r1, PC, SP etc, although a better UI than the awful VS text-based window would be nice!), but those defined in the ARM documentation (the System Control Space, NVIC etc). These are all at memory-mapped addresses, so it would appear to be a trivial task to include them in the XML register definitions files. Has anyone written the XML definitions for these registers? Is there a reason they are not included in the STxxxxxxx definitions?
December 22, 2016 at 06:16 #9843support
Are you using the latest STM32 package (should be version 4.0 under Tools->VisualGDB Package Manager)? It should contain register definitions for ARM Cortex registers.
July 26, 2017 at 10:47 #11834tw39124
ParticipantThanks, this appeared to fix it – I can now see the ARM Cortex registers.
October 27, 2017 at 19:26 #12779dabramson
ParticipantI am looking to see the Processor Core Registers in an STM32F4 chip. The ones in Figure 2 in the attachment (from PM0214 by ST).
I do have the ARM Cortex M4 node, but do not see these registers under it. I’m using 5.3R3 (build 1864) and STMDevice Package version 4.3.
Please help!
You must be logged in to view attached files.October 28, 2017 at 03:56 #12782support
Please use the via Debug->Windows->Registers command to view the CPU registers.
November 1, 2017 at 20:10 #12820dabramson
ParticipantThat window just says “No data available”.
I checked that “enable address-level debugging” is enabled under Tools->Options Debugging Node.
November 1, 2017 at 20:12 #12821support
Please try right-clicking there and selecting the register groups you need.
November 2, 2017 at 19:04 #12833dabramson
ParticipantWhen I right click in the VS Registers window it gives me a with Copy (disabled) and Select All. There are no register groups. Interestingly I can see the CPU core registers when I hover over them in the disassembly window. Any other suggestions?
November 2, 2017 at 21:55 #12835support
This could happen if the gdb stub you are using did not report the registers correctly or if VisualGDB did not parse them properly (our plugin for Segger J-Link had a bug with the registers, but it got fixed years ago). Please let us know which gdb stub you are using and also attach:
- A screenshot of the registers window with the right-click menu
- Your VisualGDB version and build number
- The full GDB log from the debug session as described here
Thanks.
March 7, 2018 at 16:34 #20334cbc
ParticipantHi.
I have the same problem as dabramson. I can’t see the processor core registers for a STM32F4 when I open:
Debug->Windows->Registers.But I found a solution.
In the watch window I can display the registers when I write:
$r0
$r1
$r2
$r3
$r12
$sp
$lr
$pc
$xpsr
$msp
$psp
$primask
$basepri
$faultmask
$controlMarch 7, 2018 at 18:01 #20337support
If those expressions work in the watch window, the gdb stub is reporting them correctly. So you should be able to right-click in the Registers window and enable other register groups (VS only enables the basic CPU registers by default).
March 8, 2018 at 08:57 #20345cbc
ParticipantHi.
Thanks for your reply.
The only options I get when I right click in the Registers window is:
Copy
Select AllMarch 8, 2018 at 18:38 #20346support
Strange, this should normally not happen. Could you please attach a screenshot of the entire VS window (and the context menu) illustrating this? It might contain some clues explaining what is going on.
March 9, 2018 at 11:35 #20349cbc
Hi. Thanks for your answer.
I have tried to attach a screenshot.
You must be logged in to view attached files.March 9, 2018 at 11:39 #20351 -
