Copy XML files
Sysprogs forums › Forums › VisualGDB › Copy XML files
  • #13200
    Helmut
    I have got my project in
    c:\Pi\PiComm\PiComm
    there are my cpp files and there is a config.xml
    I would like to copy this file automaticaly. I added *.xml to files to transfer – but it is not copied. Is there a way to do so?
    Thanks for any help
    #13203
    You can specify which file extensions are transferred on the first page of VisualGDB Project Properties (e.g. add “*.xml” to the file transfer masks).
    #13228
    Helmut
    That is what i did – it does not work. I guess the xml file is not in the right location. Can you tell me what file from which location will be transfered?
    #13229
    The settings should be pretty straight-forward (source/target directories, transfer masks), so it’s hard to tell anything beyond that without knowing more details. Please try attaching a screenshot of your transfer settings and also the path of the XML file on the Windows machine and we will try to suggest what could be wrong.
