Sysprogs forums › Forums › VisualGDB › compiler flags with cross-compiled cmake linux project
- This topic has 4 replies, 2 voices, and was last updated 5 years, 12 months ago by
March 16, 2020 at 01:17 #27645
micha
ParticipantI’m trying to add the flag “-pthread” to a cr0ss-compiled cmake project.
I’m using v5.5 preview 4.
Searching gave me this thread https://sysprogs.com/w/forums/topic/compiler-flags/ from 2 years ago and I have the feeling the menu’s have changed in the meantime as I cannot find the CFLAGS option being talked about in the thread.
When I add it to either the “CMake command” or the “Extra CMake configuration variables” I get the following build message:
“CMake Warning:
Manually-specified variables were not used by the project:-pthread
CMAKE_COLOR_MAKEFILE”Any help would be appreciated.
(Also, what is this CMAKE_COLOR_MAKEFILE?)
March 17, 2020 at 01:26 #27662micha
ParticipantFixed it some other way, for anyone else looking for this:
As pthread is a library it should be mentioned in the target link libraries.
In CMakeLists.txt edit the target_link_libraries(<your_project_name> “${LIBRARIES_FROM_REFERENCES}” pthread) < add the link here. Or if you want to do it via one of the many menu’s, it’s not in the VisualGDB project properties (or at least I couldn’t find it there). Go to the actual project properties, which is the 3rd from the top if you start a new one, right below the visualGDB project. Right click > project properties, then Linker > General > Additional inputs, here’s the previously mentioned “${LIBRARIES_FROM_REFERENCES}, expand it with a semicolon and then the library, like so: ${LIBRARIES_FROM_REFERENCES};pthread
If there’s a more visualGDB-ish method please tell, I like to keep al my settings in one menu 🙂
March 17, 2020 at 07:22 #27673support
KeymasterGood to know it works. BTW, we have a detailed tutorial showing the necessary steps here: https://visualgdb.com/tutorials/linux/cmake/target_link_libraries/
Please also feel free to try VisualGDB 5.5 Preview 4. It can automatically troubleshoot the “undefined reference” errors and suggest the necessary configuration changes.
March 17, 2020 at 10:41 #27674micha
ParticipantThank you very much for your response.
In fact I am on 5.5 preview 4. The first library (which needed the pthread) did actually automatically get added, however -pthread did not. Might this have anything to do with the fact that clang doesn’t automatically analyze the libraries added for errors?
Once again the tutorial is very good! It probably went wrong in my head for looking to add compiler flags, which I thought would be the way to go, while in fact it was a linker thing. This would have made me find the mentioned tutorial.
March 19, 2020 at 18:54 #27714support
KeymasterThe automatic library discovery is indeed not recursive, so if the added library depends on pthread, VisualGDB would only suggest adding pthread when you build the project again (and the build fails due to missing pthread functions).
There also might have been a confusion between pthread and the asan library that provides similar functions, but is intended to work as a diagnostic layer on top of pthread. We have updated VisualGDB internally to hide the confusing asan/lsan libraries when searching for pthread symbols and only suggest the pthread library itself. Until we release the next preview build with this fix, please make sure you select the pthread library when VisualGDB suggests several libraries resolving pthread symbols.
