COM Port Window Font (Raw Terminal)
Sysprogs forums Forums VisualGDB COM Port Window Font (Raw Terminal)
  • #27399
    suremicro
    Hi
    There a few posts similar to this but I haven’t been able to find a way of changing the font of the COM port window – it is a small point but the default font is very large compared with other windows. Another post (https://sysprogs.com/w/forums/topic/change-font-in-ssh-and-gdb-window/) suggested using the Tools->Options->Fonts and colors->Text Editor for the SSH and GDB windows but this does not have an affect on the COM window.
    Version: 5.4R12 (build 3309)
    Any ideas would be helpful.
    #27401
    No problem, please try this build: VisualGDB-5.5.4.3525.msi
    It uses the Command window font in the Raw Terminal as well.
    #27465
    suremicro
    Great, thank you that’s much better (however it doesn’t affect the Hex text but this is less of asn issue).
    Also the Arduino serial monitor has an option to add a timestamp for each output line that it is very useful πŸ˜‰
    #27472
    No problem, we have updated VisualGDB to apply the font to both controls. Please try this build: VisualGDB-5.5.4.3541.msi
    Timestamps for terminal output sounds like a good idea. We have added it to our backlog and will try to include it in one of the next VisualGDB releases.
    #27473
    suremicro
    Thanks for the quick response. Much appreciated.
