Clang intellisense suggestions sort by scope
Sysprogs forums Forums VisualGDB Clang intellisense suggestions sort by scope
  • #11860
    borbmizzet
    Could you please add an option to sort the clang intellisense suggestions by scope? I have a bunch of global typedefs, enums, and methods (STM32 Cube Drivers) clogging up my intellisense suggestions. Creating abstract adapters for the whole thing is not really an option right now.
    #11862
    Sorry, this is a bit too specific and non-trivial to add. We would recommend using name filtering (typing a part of the method or a class) and type filters (buttons in the suggestion window) instead.
    #11864
    borbmizzet
    I meant a sort of the autocomplete suggestions in order of scope relative to the current text being typed in the scope hierarchy, from localest level to globalest level. Like, if you’re coding a member function for a class, put matching member variables, enums, functions and structs local to the same class higher on the autocomplete list than global ones.
    #11867
    VisualGDB already allows showing the local variables on top of other suggestions via a corresponding button:
    However it does not distinguish all the possible scopes (only local variables vs. everything else).
    • This reply was modified 8 years, 8 months ago by support.
