Clang Intellisense parameter infos not working properly
Sysprogs forums Forums VisualGDB Clang Intellisense parameter infos not working properly
  • #25133
    MystikReasons
    I already opened a post for a similiar problem a while ago(https://sysprogs.com/w/forums/topic/intellisense-wrong-parameter-info/)
    One of your statement: ”
    <div class=”bbp-reply-content”>
    It looks like the ‘*’ frame around the comment is interfering with the comment parsing logic.
    Please ensure that the line containing the ‘@param’ comment does not have any other characters (other then spaces) in front of the @param part and VisualGDB will handle it correctly.
    These ‘*’ frames are also present in every HAL file (see screenshot #1) so the function infos aren’t being displayed when hovering over a function.
    My question: Would it be possible to update your logic so the ‘*’ frames arent interfering with your comment parsing logic?
    </div>
    UPDATE: Also it seems your logic for “Declared: .h file (222, 6) isn’t working properly, see screenshot #1 for the location displayed in the function info and the content at the “real” location.
    See screenshot #2 for the infos at the displayed location
    • This topic was modified 6 years, 10 months ago by MystikReasons.
    #25142
    Thanks for the update. Indeed, the comment parsing for STM32 codebase would not recognize the @param tokens, however the bigger issue there is that the comments are located in the .cpp files, not .h files and hence locating them would involve a longer go-to-definition operation that is not performed when displaying comments or argument suggestions.
    We will try to improve this in one of the upcoming VisualGDB releases.
