Clang IntelliSense navigation bar
Sysprogs forums › Forums › VisualGDB › Clang IntelliSense navigation bar
  • #24275
    SFC01
    suppose you have a class with a method taking a std::string as argument. With the native IntelliSense engine enabled, this method is displayed as
    Method(std::string argument)
    in the navigation bar. With the Clang IntelliSense engine enabled the navigation bar item looks like
    ClassName::Method(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char>>)
    Please see attached screenshots. This may be technically correct but it is unreadable, especially if you have several arguments. If the file contains a large number of methods, it becomes a pain to find a method via the navigation bar. It would be great if you could make it conform to the native IntelliSense engine. Thanks.
    VisualGDB Custom Edition version 5.4R3 build 3000
    Visual Studio Community 2017 version 15.9.9
    #24295
    No problem. We have changed the logic that fetches the item names for the navigation bar to use exactly the syntax they are declared with. Please try this build: VisualGDB-5.4.103.3013.msi
    #24314
    SFC01
    Very nice! Thank you!
