Changes in QT Designer not having an effect
Sysprogs forums Forums VisualGDB Changes in QT Designer not having an effect
  • #30577
    AndyFraser
    I have configured VisualGDB to cross compile, download and debug QT applications for Raspberry Pi.
    If I open MainWindow.ui and make changes then save the changes in QTDesigner and re-build and run the application, the changes are not evident.
    This was discussed here but a solution was never proposed:https://sysprogs.com/w/forums/topic/qt-designer/
    From that post it would seem that the ui_mainwindow.h should be generated on the Raspberry Pi and pulled into my VS solution by VisualGDB?
    Any suggestions ?
    Best Regards
    Andy
    #30578
    AndyFraser
    Interesting, ui_mainwindow.h was in the root of my solution folder.
    I deleted it to allow it to be re-created and once it was re-created it appeared not in the root of the solution but in the ..autogen\include folder and now seems to correctly track changes made in QT Designer !
    Andy
    #30580
    Unfortunately, it’s hard to suggest anything specific based on the description you provided. Please try reproducing the problem on a freshly created project. If it persists, please share the full steps to reproduce the issue from scratch, including all the relevant screenshots per our problem reporting guidelines.
    #30581
    AndyFraser
    Please see my second post – it is all working as expected now.
    It seemed it needed me to delete the ui_mainwindow.h from the root of the solution folder and allow it t be re-created in autogen\include.
    Best Regards
    Andy
    #30582
    No problem and good to know it works. It’s hard to say why it would get placed into the root folder – it could be a side effect of a specific combination of settings. If working around the problem by deleting the file works for you, no further action is necessary. If it becomes more annoying, or you suspect that there’s a bug in VisualGDB affecting the project layout, feel free to attach the repro steps and we will investigate it further.
