Sysprogs forums › Forums › VisualGDB › Can't connect to the gdbserver
- This topic has 10 replies, 2 voices, and was last updated 10 years, 9 months ago by
JulianH.
June 11, 2015 at 16:10 #6573
JulianH
i’m just porting a Visual Studio 2013 Windows Project to Linux in conjunction with VisualGDB. My building of the connections looks like:
Everything is compiling absolutly correct and the executable gets delivered correctly to 169.254.254.254, it starts even properly.
In htop on 169.254.254.254 i can see the running gdbserver with “gdbserver :2000 /tmp/VisualGDBTest” and /tmp/VisualGDBTest with “/tmp/VisualGDBTest” command line. But VisualGDB allways report if i try to debug a new instance (gdbserver and VisualGDBTest yet not run at this time) VisualGDB execute all my previosly enumerated steps then to say that gdbserver has report that the target process isn’t running. Here is the exactly appeared error message:
It allready worked but since i reinstalled VisualGDB and entered the licence key it does not.
With best regards
Julian Hindelang
June 11, 2015 at 23:48 #6574support
Please you enable GDB logging as described here and submit the detailed GDB log so that we could investigate it.
June 12, 2015 at 07:11 #6579JulianH
ParticipantJune 12, 2015 at 07:39 #6580JulianH
ParticipantIt’s maybe interesting:
This message appears immediately before the error-message posted in my first post appears:
June 12, 2015 at 18:16 #6581support
Can you ping your remote machine? If no, please check your IP address/subnet mask/gateway settings.
If yes, the firewall on the remote machine might be blocking the connections to the gdbserver. Please try disabling the firewall on the Linux side.
June 14, 2015 at 08:34 #6582JulianH
ParticipantI can connect to 169.254.254.254 to port 2000 i tested it with socat and with a gdb client by myself, both worked.
Just VisualGDB does not.
June 15, 2015 at 07:13 #6585JulianH
ParticipantMy Firewall is completly turned off, Linux side i have no Firewall and no entries in the iptables.
June 15, 2015 at 07:44 #6586JulianH
ParticipantIf i try to connect to the gdbserver started by VisualGDB by command line, i get that:
C:\Users\hindelang.j>gdb
GNU gdb (GDB) 7.6.1
Copyright (C) 2013 Free Software Foundation, Inc.
This GDB was configured as “mingw32”.
(gdb) target remote 169.254.254.254:2000
Remote debugging using 169.254.254.254:2000
warning: while parsing target description (at line 13): Target description specified unknown architecture “powerpc:commo
n”
warning: Could not load XML target description; ignoring
Remote sent bad register number 0x40: b7faaea4;thread:p402.402;core:0;
Packet: ‘T0501:bf93ba00;40:b7faaea4;thread:p402.402;core:0;’Server side:
If i connect with VisualGDB, i only get the error as descripted above (without the recognizion from the gdbserver that someone tryed to connect).
I don’t know what i am doing wrong. It simply makes no sense to me.
This reply was modified 10 years, 9 months ago by
JulianH.
June 15, 2015 at 11:24 #6588JulianH
ParticipantThe compiling linux server wasn’t in the same network like the linux execution server, i don’t understand why but putting them into the same network solved the problem.
June 16, 2015 at 20:55 #6597support
KeymasterThis can be caused by lots of different causes ranging from ip/netmask settings to your gateway routing configuration. Putting both hosts in the same network is indeed the easiest solution.
June 17, 2015 at 09:16 #6605JulianH
ParticipantSo i say thank you.
