Cannot start debuging
Sysprogs forums Forums VisualDDK/VirtualKD discussion Cannot start debuging
Viewing 6 posts - 16 through 21 (of 21 total)
  • #1745
    OK. That explains. To debug your driver you need either another physical PC, or a virtual machine.
    The easiest way is to install VirtualBox (it is free), install Windows into it, setup the VirtualKD back-end (go to http://visualddk.sysprogs.org/, look for vminstall), reboot your VM in debug mode and select it in the “Virtual Machine” combo box.
    #1746
    Saman
    But I want debug on a second machine and IP adress at Target machine field is adress of the second machine,so how I must set Debug launch dialog for debugging on a second machine?
    #1747
    In order to debug a driver on a second machine, you either need either a direct COM, or FireWire connection. This is a general limitation related to driver debugging and is not VisualDDK-specific.
    #1748
    Saman
    Hmm, I thought it may be also over network, and what is needed IP adress
    #1749
    The IP address is needed to control the driver and update its binary automatically. Otherwise, you would have to copy the file and start the service manually.
    #1760
    Thank you so much for this thread, it saved me a lot of time. I didn’t have the virtual machine setup… πŸ™‚
