Cannot start debugging
Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Cannot start debugging
Viewing 13 posts - 31 through 43 (of 43 total)
  • #1837
    jlam9012
    I attached a screenshot of the call stack. let me know if this helps/ is right
    #1838
    This helps partially. Please get symbols for both MSDIA100 and DDKDebugger-dbg:
    1. Download http://visualddk.sysprogs.org/DDKDebuggerPDB.zip
    2. In Visual Studio right-click on a line containing msdia100.dll, select Load Symbols -> From microsoft servers
    3. Right-click on a line containing DDKDebugger-dbg, select Load Symbols -> From file, specify the PDB file from the archive
    This should update the call stack and make it more informative. Please submit a new screenshot.
    #1839
    jlam9012
    Here’s the screenshot with symbols loaded
    #1840
    That looks like a strange bug in VS2010. Do you have the latest service pack installed? If yes, please create a dump file using Visual Studio (Debug->Save dump as) and submit a link to it here.
    As another workaround I can suggest getting msdia.dll from VS2008 and registering it in your system. VisualDDK will automatically use it instead.
    #1841
    jlam9012
    I do not have the latest service pack installed. I will install that and see what happens.
    #1842
    jlam9012
    Installing service pack 1 did not correct the issue but using the VS 2008 .dll file did! However, now when trying to “load driver” in visualddk I do not believe it is detecting the local ip address correctly. I attached a screenshot of the DDklaunchmonitor on the VM and it only lists one local IP address…I feel like this is incorrect.
    #1843
    Is your firewall blocking the connections to the target machine?
    #1844
    jlam9012
    I have windows firewall turned off on both the host and guest machines
    #1845
    What does the launch window in Visual Studio show? What happens if you press “refresh”?
    #1846
    jlam9012
    Nothing happens when I press “refresh”
    #1847
    Then you don’t have a network connection between the VM and the host machine. Try adding another network card in the VM settings and selecting “host-only” as the connection type.
    #1848
    jlam9012
    That fixed it, I am now debugging the sample driver as in the tutorial. Thank you so much I really appreciate all the help.
    #1849
    Is there a solution found – i’ve same problem now
