Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Cannot start debugging
- This topic has 42 replies, 3 voices, and was last updated 13 years, 5 months ago by
Anonymous.
June 29, 2011 at 20:33 #317
I am trying to build and debug a driver that performs registry callbacks and i’ve been trying to get Visual DDK to work. I’ve successfully installed it on my host machine and VM. Now, I’m just having some issues with using my source files and getting it to build and debug.
I load my own source files and put everything in the project folder. I also have a ‘sources’ file because I use the WinDDK build. Here is my sources file:
TARGETNAME = wlreg TARGETTYPE = DRIVER LINKER_FLAGS=$(LINKER_FLAGS) /IGNORE:4210 TARGETLIBS = $(DDK_LIB_PATH)ntoskrnl.lib $(DDK_LIB_PATH)wdmsec.lib INCLUDES = ..;....include; SOURCES = ..Capture.cpp ..Device.cpp ..Driver.cpp ..Filter.cpp ..MultiQueue.cpp ..Process.cpp ..BufferWriter.cpp FilterWin7.cppDo I have to do anything special in Visual Studio project properties to get it to build?
June 29, 2011 at 20:59 #1808support
KeymasterYou can either create a new “make project” so that Visual Studio will invoke “build”, or use VisualDDK project wizard and select “use existing files” to have the project created for you.
June 30, 2011 at 15:56 #1809jlam9012
ParticipantI tried selecting ‘use existing files’ with the VisualDDK project wizard. Here is the build output:
1> Build started: Project: Driver1, Configuration: Debug Win32 1>Build started 6/30/2011 11:23:10 AM.
1>Build:
1> OACR monitor running already
1> path contains nonexistant c:program files (x86)microsoft visual studio 10.0common7toolsbin, removing
1> BUILD: Compile and Link for x86
1>
1> BUILD: Loading c:winddk7600.16385.1build.dat...
1>
1> BUILD: Computing Include file dependencies:
1>
1> BUILD: Start time: Thu Jun 30 11:23:10 2011
1> BUILD: Saving c:winddk7600.16385.1build.dat...
1>
1> BUILD: Finish time: Thu Jun 30 11:23:11 2011
1> BUILD: Done
1>
1>
1>
1> 0 files compiled - 1 Warning
1>
1>
1>Build succeeded.
1>
1>Time Elapsed 00:00:01.14
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
June 30, 2011 at 16:01 #1810jlam9012
ParticipantI tried selecting “use existing files” in the VisualDDK Project Wizard and got this build output:
1>Build:
1>
1>
1>
1>
1> BUILD: Done
1>
1>
1>
1>
1>
1>Build succeeded.
1>
June 30, 2011 at 22:19 #1811jlam9012
ParticipantPlease disregard my last 2 posts. I was able to get the driver to successfully build in Visual studio – hooray!!
But now, it gives me the error
“VisualDDK: Cannot start debugging: One of the library files needed to run this application cannot be found.”
The driver does successfully build – all my source files compile and I get a .sys file.
July 1, 2011 at 12:34 #1812support
KeymasterHi, try this build: http://visualddk.sysprogs.org/test/VisualDDK-1.5.3.exe
July 1, 2011 at 18:14 #1813jlam9012
I tried that but still getting same error 🙁
July 2, 2011 at 09:13 #1814support
KeymasterDid you install the 32-bit Debugging tools?
July 5, 2011 at 13:40 #1815jlam9012
ParticipantOn the host machine or virtual machine?
July 5, 2011 at 14:36 #1816support
Keymasterhost machine
July 7, 2011 at 15:13 #1817jlam9012
ParticipantYes, I have installed the 32 bit debugging tools for windows on the host machine
July 10, 2011 at 12:37 #1827support
KeymasterPlease download VisualDDK 1.5.4, select “register debug version of DDKDebugger.dll” in installer, run Visual Studio as administrator, attempt debugging and post the DDKDebugger.log file from VisualDDK directory here. The log file should contain problem details.
July 11, 2011 at 12:34 #1826jlam9012
ParticipantDDKDebugger.log
Initializing MSDBG session…
Loading dbgtools DLLs from C:Program Files (x86)Debugging Tools for Windows (x86)…
Session initialized successfully.+ 0.000 [ 0 ms]: MSDbgSession::UpdateOutputMask()
Session status changed to 4
+ 0.015 [ 2840 ms]: BasicMSDbgSession::StartSession()July 11, 2011 at 12:37 #1824support
KeymasterOK, I am assuming the problem occurs because the launcher cannot find the compiled sys file. You can try experimenting with the launcher settings, or installing the driver manually and using the Debug->Attach dialog to attach to the target machine.
July 11, 2011 at 20:26 #1825jlam9012
ParticipantOk, I changed the “Driver file path on the target machine” to where my driver is on the vm. My driver is named wlreg.sys but it keeps trying to find Driver1.sys (Driver1 is the name of my VS project). How can i get it to stop searching for Driver1.sys…do I have to change the VS project name to the name of my driver?
