Sysprogs forums › Forums › WinCDEmu › Cannot Mount Devices under Windows 7 Pro x86
- This topic has 6 replies, 2 voices, and was last updated 16 years, 1 month ago by
January 9, 2010 at 09:17 #140
ParticipantI’m having a strange issue that doesn’t appear to be listed… I’m currently running the latest version of Windows 7 x86 Professional Edition, and while the installation went just fine I can’t seem to mount anything. The “Select Drive Letter & Mount” option appears when I right click on an image files, it launches vmnt when I double click, and the first time I click an image it even makes the ‘mounted’ sound. However, beyond that noise absolutely nothing seems to happen. No new drive letter, no mounted disk. I’m using the latest version of Wincdemu, 3.1. Any hep you can give would be greatly appriciated, as I much prefer wincdemu to the other image mounting tools out there.
January 9, 2010 at 19:03 #1275Anonymous
ParticipantI’m getting the same thing, windows 7 x86. Not sure if I heard a mount sound, but it just won’t go – no drive letter appears. I thought it might be a UAC problem but I have UAC turned completely off.
January 9, 2010 at 19:06 #1276Anonymous
ParticipantRunning WINCDEMU 3.1 12-6-09
January 12, 2010 at 14:32 #1277Anonymous
Participantsame here under vista x86. even worse, i get blue screen at shutdown. running version 3.1
January 12, 2010 at 14:44 #1278support
KeymasterOk, please gather all .dmp files from your WindowsMinidump directory, pack them into a ZIP file and send to support (at) sysprogs.org. This will help me to determine the reason of the problem and to fix it.
January 13, 2010 at 09:28 #1279Anonymous
ParticipantSorry if I’ve somewhat high-jacked the thread from Windows 7. But all the symptoms described by chrysalisx were the same on my Vista (Home Premium, SP2), plus the blue screen at shutdown.
I was able to get v2.3 to work though.
Then I saw this thread:
http://forum.sysprogs.org/viewtopic.php?f=3&t=115although it is a bit different in that the blue screen only comes up when Windows is shutting down.
That’s when I remember that my system came preloaded with a bunch of Roxio apps. After removing those programs, v3.1 is now working on my Vista.
February 21, 2010 at 05:04 #1280support
KeymasterOk, this seems to be some kind of incompatibility. WinCDEmu 3.x uses a new ‘virtual SCSI’ model to create virtual drives. However, most advanced commands (that go beyond just reading some data) are replied with “not supported” status. I guess, this confuses many 3rd-party products (e.g. Roxio) and causes them to crash. That also explains why I cannot reproduce the bug on any of my machines.
I will look towards including a ‘debug mode’ in the next release of WinCDEmu that will collect precise records of all received requests, so I will be able to understand why the 3dr-party components get confused. You can also e-mail Roxio techsupport, as, if their driver actually causes blue screens, the bug is contained in it and WinCDEmu can just provide a workaround by responding to more non-essential requests… -
