Sysprogs forums › Forums › VisualGDB › Can VGDB cope with >1 STlink attached at a time?
- This topic has 8 replies, 2 voices, and was last updated 10 years, 4 months ago by
May 9, 2016 at 15:57 #8184
Ken Macfarlane
ParticipantI need to debug 2 targets at opposite ends of an rs232, each with its own app & each with its own debugger. Once I’ve got one up & running, when I try to start the debugger in the 2nd instance of Visual Studio, I get a load of guff from OpenOCD, which doesn’t happen if the first target’s debugger isn’t connected. Is there a switch somewhere in the VGDB properties that I’ve missed? I can’t seem to get the first target to run from flash either, although it will when there’s only one debugger & one instance of VS.
May 10, 2016 at 04:51 #8192support
This is not supported yet, however we will consider adding a switch to the upcoming update of our OpenOCD package that we expect to release this week.
May 11, 2016 at 06:30 #8203support
KeymasterOK, we have released an update that supports it. Please update your OpenOCD package to 0.9.0r9.
May 17, 2016 at 16:15 #8227Ken Macfarlane
ParticipantSorry, but I can’t see how to update openOCD . Is this something that I can do from within VS? Also, I don’t know how to tell what version I’m using – it’s dated May 6th, 2016. I’ve poked about under the “Show help on configuring OpenOCD” link on the Debug Settings tab under Project Properties for example.
May 17, 2016 at 16:55 #8228support
KeymasterPlease use Tools->Embedded Tools Manager->Check for updates.
Please also update VisualGDB to 5.1r6 as the previous versions have a known issue that sometimes corrupts OpenOCD settings with the new OpenOCD.
May 18, 2016 at 10:20 #8238Ken Macfarlane
ParticipantFound it – under Install Support for Additional debug methods (on the Debug Method Tab), it allows you to update any of the debuggers installed. Note that when you test the OpenOCD settings, it says e.g
Open On-Chip Debugger 0.9.0 (2016-05-03), but doesn’t actually give the revision (it must have been r8 here, because now the dates changed to 2016-05-10 & r9)
May 18, 2016 at 10:40 #8239Ken Macfarlane
ParticipantOh, and VS has to be restarted after you update OpenOCD, or you get a bogus message about the memory at the stack location not being writeable!
May 18, 2016 at 16:48 #8240Ken Macfarlane
ParticipantDon’t think this works properly yet – the Select a USB Device lists 2 identical debuggers – same Programmer type, Windows device name, Vendor ID, Device ID & Interface (ST-Likn v2.1, St Microelectronics ST.., 0483, 374B & 00 in my case). Although I can pick one, regardless of which one I pick, the OpenOCD test exits with code 1.
May 19, 2016 at 04:44 #8241support
KeymasterPlease check the actual output of OpenOCD. It should contain information about the specific error. If you are not sure, please post the output here so that we could help you.
